rungekutta
- May 11, 2016
Ok I need help...
Setup: Supermicro X11SSM-F, Intel i3, 32GB ECC Samsung RAM
2x onboard Intel NICs + 1x IPMI
3x WD RED + 3x Seagate NAS 3TB in RAIDZ2
FreeNAS-11.1-U4 running on bare metal.
So I recently replaced my humble Airport Extreme router with OpnSense running on a fanless Qotom Q355G4 MiniPC with 4 Intel NICs. Idea being to increase performance (I've got 1Gb WAN) and enable a LAN/DMZ setup to isolate home LAN from VMs with ports open to the Internet.
The FreeNAS machine has one NIC on the LAN and one on the DMZ. Later and when I'm done it will probably be on LAN only, although I still need to access some NFS shares from the DMZ so not quite decided yet.
Anyhow so far so good except I've run into a very odd network problem which seems isolated to FreeNAS. Weird TCP errors and/or dropped packets.
When I iperf on same subnet or across subnets (through OpnSense (LAN and DMZ, vice versa, for testing)) I get consistent >900Mbit as expected, when I try between MacOS and Windows clients vs Linux VMs (in ESXi). So the network infrastructure and the firewalling (across subnets) looks fine. However as FreeNAS gets involved, things get weird.
iPerf in UDP mode (-u) looks ok. However with TCP things go horribly wrong (in this case from MacOS client):
(DMZ is 192.168.1.0/24, LAN is 192.168.200.0/24)
iPerf against the NIC on the same subnet however, also in the case of FreeNAS, behaves as expected. So the problems only occur when crossing subnets, in either direction.
Similarly, if I try to scp a file across subnets and FreeNAS is involved, the transfer stalls and times out but not always immediately. And I can connect to the web front end, so some stuff does get through.
I have the following tunables, to set Cubic instead of newreno and slightly larger default send and receive buffers:
Haven't tried reverting back to newreno but tried messing with the buffers including the more conservative defaults, but no difference.
I've disabled pf scrubbing in OpnSense and trimmed it down to a pretty minial setup. It runs on FreeBSD 11.1 like FreeNAS.
I'm at a total loss (no pun intended!) from here... so would greatly appreciate some pointers for further troubleshooting!
Many thanks in advance.
foo$ ./iperf3 -c 192.168.200.10
Connecting to host 192.168.200.10, port 5201
[ 4] local 192.168.1.174 port 49559 connected to 192.168.200.10 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.01 sec 210 KBytes 1.71 Mbits/sec
[ 4] 1.01-2.01 sec 0.00 Bytes 0.00 bits/sec
[ 4] 2.01-3.01 sec 0.00 Bytes 0.00 bits/sec
[ 4] 3.01-4.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 4.00-5.01 sec 0.00 Bytes 0.00 bits/sec
[ 4] 5.01-6.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 6.00-7.01 sec 0.00 Bytes 0.00 bits/sec
[ 4] 7.01-8.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 8.00-9.01 sec 0.00 Bytes 0.00 bits/sec
[ 4] 9.01-10.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 0.00-10.00 sec 210 KBytes 172 Kbits/sec sender
[ 4] 0.00-10.00 sec 65.0 KBytes 53.3 Kbits/sec receiver
net.inet.tcp.cc.algorithm=cubic
net.inet.tcp.recvspace=613200
net.inet.tcp.sendspace=613200
