lletourn
- Aug 21, 2018
I'm wondering if there was an easy way to setup Cross Origin Resource Sharing (CORS) in WebDAV on FreeNAS (FreeNAS-11.1-U5)?
Long explanation:
I'm trying to use our FreeNAS server to host and serve HLS (m3u8) videos. For this to work I need to have CORS enabled. Is there an easy way to do this under FreeNAS?
The complicated way is to actually modify the webserver config files under FreeBSD, but I'd think there would be a simpler way.
The other solution would be to have a separate web server, which I think is overkill since the FreeNAS server already has all the parts...
Thank you.
Louis
Long explanation:
Thank you.
Louis
