I'm swapping some drives so I've been trying to do 2 different operations and running into major slowdowns and instability with both of them, particularly when running these operations on multiple drives at once.
1. Running "sg_format -F /dev/sdX" to remove Data Integrity Feature from the drives I'm installing. While running this, I get repeated console errors that the SMART information on the drives can't be accessed, which I think is expected while they are formatting. What's not expected is, while running this on 3 drives the web UI became unresponsive. At least I could check progress with "sg_format -v /dev/sdX" in the console. I'm pretty sure I've done this on earlier versions of Truenas (possibly Core) in the past without that behavior.
2. Wipe drives with zeroes using the button in the GUI Disks menu. I am trying to do 6 at once. In a VM with 12GB of RAM the WebUI and console both became unresponsive. The last thing I was able to do was run htop and see "middlewared" was maxing out my CPU. I needed to use that server so I rebooted and moved the disks to a bare metal server with 32GB of RAM to wipe them. This is currently running as expected with stable web UI access, but the 32GB of RAM did max out almost instantly which seems strange with basically nothing going on except wiping disks.
Anybody experienced this? Is it a new bug in Cobia?
