Web interface not available after installation of 11.0 RC
Sparx
So I just upgraded to 11.0 RC from 9.10.2-U3 and the install looks to have been okay according to screen printouts.
Normal screen shows the menu as usual (except now its Console setup and then 1-12.).
Nginx reports an error on the webpage like this:
An error occurred.
Sorry, the page you are looking for is currently unavailable.
Please try again later.
If you are the system administrator of this resource then you should check the error log for details.
Faithfully yours, nginx.
 restarting nginx and django
root@freenas:~ # service nginx restart
Performing sanity check on nginx configuration:
nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
Stopping nginx.
Waiting for PIDS: 8556.
Starting nginx.
root@freenas:~ # service django restart
Stopping django.
Waiting for PIDS: 8621.
Sparx
HW:
Xeon-D 1528
64GB 2133 RDIMM
8x6TB SAS over LSI 3008 HBA conf as RAIDZ2
Might be worth a bug report (if there isn't one already).
Sparx
So I'm looking in the bug reporting tool but cant find anything related to this. This is the first time reporting a bug for me. Can you double check so I don't do anything unneeded?
SweetAndLow
Sweet'NASty
Just file it. If it's a dupe they will take care of it.
Sparx
Yeah that was me. But a clear of browser data solved it. I wouldnt have solved it without the bug report. =) There was a logfile that stated my old Openmediavault nas history and Crome Clear of cookies and cached images fixed the issue.
Sparx
So now is just the question. Where the heck is the new gui? Is it on some other port or should i enable it some magical place?
Edit: Oh man i clicked every menu for it. But of course it was when logging in. Dammit! :D
