After upgrading to 8.2.0-RELEASE-p1-x64 recently I thought I'd try configuring my own SSL cert using the web GUI again after reading that the previous issues with this feature had been resolved. Unfortunately I've managed to lock myself out of the GUI by using an incorrect key! The GUI is configured to use SSL and it's no longer accessible. I try using HTTP instead and it reverts (understandably) to HTTPS during the login process.
I found the cert and key files in /etc/ssl/freenas/nginx and edited them with the correct contents for my SSL cert, but they got overwritten again on reboot (I assume from the details stored in the config DB?)
Other than restoring the config from a previously saved backup, is there an easy way to either allow me to manually enter the correct key file contents or configure the GUI to be served over HTTP rather than HTTPS?
Thanks in advance for your help.
