Scottijwnh1963
- Dec 1, 2013
I am trying to install the Web GUI for the Highpoint Rocket RAID 2720sgl and I am having problems. I am an experienced MS computer user but cannot wrap my head around linux/unix/freebsd way of doing things. So here I am looking for help.
First let me say I have checked around and have not been able to find enough help to get me through this issue.
I am using FreeNAS x64 9.2.1.9 and I found an article using FreeNAS 9.1.1 installing the Web GUI, but when I try to use it I get errors. So I was hoping to list the procedure and someone could take a look at it and do a reality check and tell if this will work. First I made a jail and then entered the jails shell.
Listing from WebGUI install procedure.
#Installs raid webgui for rocketraid 2310
# make usr folder RW (read only on Freenas 9.1.1)
mount -rw /
#Create a 25MB RAM drive /var/tmp (for using pkg_add)
mdconfig -a -t malloc -s 25M -u 10
newfs /dev/md10
mount /dev/md10 /var/tmp
#Create a 20MB RAM drive /usr/share/hpt (destination folder
for install)
mdconfig -a -t malloc -s 20M -u 11
newfs /dev/md11
mkdir /usr/share/hpt
chmod 777 /usr/share/hpt
mount /dev/md11 /usr/share/hpt/
#download the file
fetch http://www.highpoint-tech.com/BIOS_Driver/HRM/FreeBSD/WebGUI-FreeBSD-v2.1.4- 130401.tgz
tar zxvf WebGUI-FreeBSD-v2.1.4-130401.tgz
#install the deamon
pkg_add hptsvr-https-2.1.4-13.0401.tbz
After that use your browser to go to
http://freenasip:7402/
Username: RAID
password: hpt
So the first error I get is below and this is from within the jail shell created.
root@Web:/ # mount -rw /
mount: /: unknown special file or file system
Any help would be appreciated.
Thank you,
Scott
mount -rw /
newfs /dev/md10
for install)
newfs /dev/md11
#download the file
#install the deamon
Username: RAID
password: hpt
Thank you,
Scott
