Web Gui Dies in 9.1.1
skl111
I have installed Freenas 9.1.1
I installed 5 plugins, plex, dlna, sickbeard, sab+,plex
After a while the nginx dies and I find this error in the logs.
013/11/17 17:22:16 [error] 32693#0: *1 connect() to 127.0.0.1:9042 failed (61: Connection refused) while connecting to upstream, client: 192.168.2.103, server: localhost, request: "GET / HTTP/1.1", upstream: "fastcgi://127.0.0.1:9042", host: "192.168.2.11"
2013/11/17 17:22:16 [error] 32693#0: *1 kevent() reported that connect() failed (61: Connection refused) while connecting to upstream, client: 192.168.2.103, server: localhost, request: "GET /favicon.ico HTTP/1.1", upstream: "fastcgi://127.0.0.1:9042", host: "192.168.2.11"
2013/11/17 17:22:25 [error] 32693#0: *1 kevent() reported that connect() failed (61: Connection refused) while connecting to upstream, client: 192.168.2.103, server: localhost, request: "GET /favicon.ico HTTP/1.1", upstream: "fastcgi://127.0.0.1:9042", host: "192.168.2.11"
I reboot and the system works for a while.
I should add I am actively using sickbeard+sab + when it dies.
The NAS page and all the plugin pages go down.
skl111
4gb ram
X3 b73 Amd CPU
Broad com dual port pci e bge nic.
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=80099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,LINKSTATE>
        ether 00:e0:ed:08:9e:32
        inet6 fe80::2e0:edff:fe08:9e32%bge0 prefixlen 64 scopeid 0x1
        nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL>
        media: Ethernet autoselect (none)
        status: no carrier
bge1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        inet6 fe80::2e0:edff:fe08:9e33%bge1 prefixlen 64 scopeid 0x2
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
re0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
        ether b8:97:5a:03:bc:35
        status: no carrier
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
        options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0xd
lagg0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        omitted
        inet6 fe80::2e0:edff:fe08:9e32%lagg0 prefixlen 64 scopeid 0xe
        status: active
        laggproto lacp lagghash l2,l3,l4
        laggport: bge1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
        laggport: bge0 flags=0<>
        ether 02:7a:83:8c:f3:00
        member: epair4a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 20 priority 128 path cost 2000
        member: epair3a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 19 priority 128 path cost 2000
        member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 18 priority 128 path cost 2000
        member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 17 priority 128 path cost 2000
        member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 16 priority 128 path cost 2000
        member: lagg0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 14 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:39:8b:00:10:0a
        inet6 fe80::39:8bff:fe00:100a%epair0a prefixlen 64 scopeid 0x10
        status: active
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:63:6b:00:11:0a
        inet6 fe80::63:6bff:fe00:110a%epair1a prefixlen 64 scopeid 0x11
        status: active
epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:79:26:00:12:0a
        inet6 fe80::79:26ff:fe00:120a%epair2a prefixlen 64 scopeid 0x12
        status: active
epair3a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:d0:75:00:13:0a
        inet6 fe80::d0:75ff:fe00:130a%epair3a prefixlen 64 scopeid 0x13
        status: active
epair4a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:88:c4:00:14:0a
        inet6 fe80::88:c4ff:fe00:140a%epair4a prefixlen 64 scopeid 0x14
        status: active
One Note, I still have access to file shares
skl111
Well i did some looking around and found that this is the script that dies.
/usr/local/bin/python /usr/local/www/freenasUI/manage.py runfcgi method=threaded host=127.0.0.1 port=9042 pidfile=/var/run/django.pid
I start it backup and the webserver works again. And made this script in cron for 5 min intervals.
#!/bin/bash
# Check if gui is running
if ps wwax | grep "[f]reenasUI" > /dev/null
then
    echo "Running" > /dev/null
else
    echo "Stopped" > /dev/null
fi
Dusan
#!/bin/bash
then
else
fi
You can replace the entire script by "service django start". It will check if the GUI is running and start it if it isn't.
Cordel
I'm seeing the same issue on a test machine I just setup.
Intel(R) Pentium(R) D CPU 2.80GHz
4GB ECC RAM
Everything is Vanilla, fresh install from CD on to a Micron USB flash card. I have set the admin password, and enabled the console on the serial port.
Set up a pair of drives in a ZFS stripe, Created a dataset for the jail/plugin services, and set the path and IP for the jails. No other changes.
For sanity, I set the gui, to the IP of the NIC.
I might get to view a few pages or change a setting before it disappears.
I have also tried reinstalling, burning a new CD with a fresh ISO.
/usr/local/bin/python -m pdb /usr/local/www/freenasUI/manage.py runfcgi method=threaded host=127.0.0.1 port=9042 pidfile=/var/run/django.pid
> /usr/local/www/freenasUI/manage.py(30)<module>()
-> import sys
(Pdb) c
The program exited via sys.exit(). Exit status:  0
-> import sys
Request Method: GET
Request URL: http://192.168.120.6/system/info/?dojo.preventCache=1386449131667
Software Version: FreeNAS-9.1.1-RELEASE-x64 (a752d35)
Exception Type: CalledProcessError
Exception Value:
Command '['sysctl', '-n', 'hw.physmem']' returned non-zero exit status -11
Exception Location: /usr/local/lib/python2.7/subprocess.py in check_output, line 575
Server time: Sat, 7 Dec 2013 12:45:32 -0800
Traceback
Environment: Software Version: FreeNAS-9.1.1-RELEASE-x64 (a752d35) Request Method: GET Request URL: http://192.168.120.6/system/info/?dojo.preventCache=1386449131667 Traceback: File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response 109. response = middleware_method(request, callback, callback_args, callback_kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view 165. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 25. return view_func(request, *args, **kwargs) File "/usr/local/www/freenasUI/../freenasUI/system/views.py" in system_info 104. sysinfo = _system_info(request) File "/usr/local/www/freenasUI/../freenasUI/system/views.py" in _system_info 71. subprocess.check_output(['sysctl', '-n', 'hw.physmem']) File "/usr/local/lib/python2.7/subprocess.py" in check_output 575. raise CalledProcessError(retcode, cmd, output=output) Exception Type: CalledProcessError at /system/info/ Exception Value: Command '['sysctl', '-n', 'hw.physmem']' returned non-zero exit status -11
Request information
GET
VariableValue
dojo.preventCache u'1386449131667'
POST
No POST data
FILES
No FILES data
COOKIES
VariableValue
csrftoken 'A4guFw3E54O9MvIMt1Xv5PgJCtsTye5g'
sessionid 'dx2l2a17qk7ro1gmvw836ghzn2ndw7p5'
fntreeSaveStateCookie 'root%2Croot%2F90%2Croot%2F1%2Croot%2F11%2Croot%2F11%2F15%2Croot%2F11%2F32%2Croot%2F11%2F36'
META
VariableValue
wsgi.multiprocess False
HTTP_REFERER 'http://192.168.120.6/'
REDIRECT_STATUS '200'
SERVER_SOFTWARE 'nginx/1.4.1'
SCRIPT_NAME u''
REQUEST_METHOD 'GET'
PATH_INFO u'/system/info/'
SERVER_PROTOCOL 'HTTP/1.1'
QUERY_STRING 'dojo.preventCache=1386449131667'
CONTENT_LENGTH ''
HTTP_USER_AGENT 'Mozilla/5.0 (Macintosh; Intel Mac OS X 10.8; rv:25.0) Gecko/20100101 Firefox/25.0'
HTTP_CONNECTION 'keep-alive'
HTTP_COOKIE 'csrftoken=A4guFw3E54O9MvIMt1Xv5PgJCtsTye5g; sessionid=dx2l2a17qk7ro1gmvw836ghzn2ndw7p5; fntreeSaveStateCookie=root%2Croot%2F90%2Croot%2F1%2Croot%2F11%2Croot%2F11%2F15%2Croot%2F11%2F32%2Croot%2F11%2F36'
SERVER_NAME 'localhost'
REMOTE_PORT '60544'
wsgi.url_scheme 'http'
SERVER_PORT '80'
SERVER_ADDR '192.168.120.6'
DOCUMENT_ROOT '/usr/local/etc/nginx/html'
HTTP_X_REQUESTED_WITH 'XMLHttpRequest'
DOCUMENT_URI '/system/info/'
wsgi.input <flup.server.fcgi_base.InputStream object at 0x80e01cd90>
HTTP_HOST '192.168.120.6'
wsgi.multithread True
HTTP_CONTENT_TYPE 'application/x-www-form-urlencoded'
REQUEST_URI '/system/info/?dojo.preventCache=1386449131667'
HTTP_ACCEPT 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8'
wsgi.version (1, 0)
GATEWAY_INTERFACE 'CGI/1.1'
wsgi.run_once False
wsgi.errors <flup.server.fcgi_base.TeeOutputStream object at 0x80e01cd10>
REMOTE_ADDR '192.168.120.160'
HTTP_ACCEPT_LANGUAGE 'en-US,en;q=0.5'
CSRF_COOKIE u'A4guFw3E54O9MvIMt1Xv5PgJCtsTye5g'
HTTP_ACCEPT_ENCODING 'gzip, deflate'
  File "/usr/local/www/freenasUI/manage.py", line 40, in <module>
    from django.core.management import execute_from_command_line
  File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 9, in <module>
    from django.core.management.base import BaseCommand, CommandError, handle_default_options
  File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 15, in <module>
    from django.utils.encoding import force_str
  File "/usr/local/lib/python2.7/site-packages/django/utils/encoding.py", line 5, in <module>
    from decimal import Decimal
SystemError: invalid comp_op: �
I don't know enough about python or dojango to go through it my self. It obviously starts with no errors.
But most often all I see is the red explanation point with "Sorry an error has occurred."
Hope this helps a little.
Edit to add more error detail.
Cordel
I have done Two things this last round of reloading, and thus far appear to have rid myself of django diving off.
Prior to reloading I removed the ZFS Volumes from both drives and wiped them (They did have a Vol from 8.3 which was the last test I had done).
Then reloaded FN.
So I'm wondering why importing a ZFS Volume set might be an issue?
After four reloads, the drives were the only thing that "Aint Vanilla" so I decided I had to try.
I'll have to see later if I can replicate it, and try to pin it down, specially if it does have anything to do with importing a zfs set.
