- Nov 25, 2013
Hi, all
when a colleague wanted to upgrade the 4 disks in his home FreeNAS to 4 TB each, WD was the first brand I checked. The "RED" series seemed to be exactly what we needed. Sacrificing performance for low power consumption was perfectly OK for a home system, 24x7 certified, ... deal.
OK, scrub pool once more to be absolutely sure, yank one drive (RAIDZ2), replace, then,
Resilvering went without a hitch, but this morning I found:
and
(shortened for brevity, same error message with a couple of retries ...)
So ...
any idea, what's going on here? I searched the forum for the "RED" drives but only found they *should* be OK. I suspect the drive is spinning down after some idle time and not coming back up.
This link was mentioned in one of the threads:
http://support.wdc.com/product/download.asp?groupid=619&sid=201&lang=en
Has anyone used this utility and can share some experience? Can I disable spin down altogether with this? The documentation only mentions increasing the idle timeout.
In the FreeNAS UI spin down is set to never. The FreeNAS version is 9.2.1.8 amd64. System is a ProLiant Micro Server N36L with 16G of ECC RAM. Drive label reads SATA/64MB Cache WD40EFRX NASware 3.0.
Any helpful suggestions (other than returning the drives ;-) appreciated.
Thanks
Patrick
gpart create -s gpt ada0 gpart add -a 1m -s 4g -t freebsd-swap ada0 gpart add -a 1m -t freebsd-zfs ada0 zpool replace zfs 6290575096370306780 ada0p2
NAME STATE READ WRITE CKSUM zfs DEGRADED 0 0 0 raidz2-0 DEGRADED 0 0 0 replacing-0 UNAVAIL 0 0 0 6290575096370306780 UNAVAIL 0 0 0 was /dev/gptid/d2e7908a-41a7-11e3-ada8-1cc1de188788 16410848062825837533 REMOVED 0 0 0 was /dev/ada0p2 ada1p2 ONLINE 0 0 0 ada2p2 ONLINE 0 0 0 ada3p2 ONLINE 0 0 0
and
Nov 25 23:03:02 freenas-je kernel: (ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 80 a0 c4 23 40 b3 00 00 00 00 00 Nov 25 23:03:02 freenas-je kernel: (ada0:ahcich0:0:0:0): CAM status: ATA Status Error Nov 25 23:03:02 freenas-je kernel: (ada0:ahcich0:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) Nov 25 23:03:02 freenas-je kernel: (ada0:ahcich0:0:0:0): RES: 41 10 a0 c4 23 40 b3 00 00 00 00 Nov 25 23:03:02 freenas-je kernel: (ada0:ahcich0:0:0:0): Retrying command Nov 25 23:03:02 freenas-je kernel: (ada0:ahcich0:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00 Nov 25 23:03:02 freenas-je kernel: (ada0:ahcich0:0:0:0): CAM status: Command timeout Nov 25 23:03:02 freenas-je kernel: (ada0:ahcich0:0:0:0): Retrying command Nov 25 23:03:02 freenas-je kernel: ada0 at ahcich0 bus 0 scbus0 target 0 lun 0 Nov 25 23:03:02 freenas-je kernel: ada0: <WDC WD40EFRX-68WT0N0 82.00A82> s/n WD-WCC4ENNRS0ZK detached Nov 25 23:03:02 freenas-je kernel: (ada0:ahcich0:0:0:0): Periph destroyed
So ...
Thanks
Patrick
