Does anyone know what this means.... (tank is the name of the pool)
Full screenshot of message...
I'm also getting this error in an alert every couple hours...
"These running processes are using tank" - python3.8 - python3.8
The following alert has been cleared: * Failed to check for alert VolumeStatus: Traceback (most recent call last): File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/alert.py", line 706, in __run_source alerts = (await alert_source.check()) or [] File "/usr/local/lib/python3.8/site-packages/middlewared/alert/source/volume_status.py", line 31, in check for vdev in await self.middleware.call("pool.flatten_topology", pool["topology"]): File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1233, in call return await self._call( File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1202, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1106, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool.py", line 431, in flatten_topology d = deque(sum(topology.values(), [])) AttributeError: 'NoneType' object has no attribute 'values'
