I'm wanting to build a seriously fast server, this will be for VMware hosts to connect to it.
It's with work, and we do a lot with IBM/Lenovo, hence using that for the server (we are in Australia, and so far I don't see a practical way to get a iX server with on site warranty, so a custom build it is).
The current config I'm looking at is:
This, in theory, based on my limited experience, should be seriously fast.
We currently use FreeNAS with 12X 500GB SSD's, however still regularly have odd slowdowns - however I suspect the issue here is the RAID card.
Is there anything this config would need to more fully benefit from using the Intel 750 series. The specifications for these cards is insane compared to using SSD SATA/SAS drives with RAID cards, and relatively good value for that type of performance. I'm assuming here that FreeNAS would also be able to max out the system to get the throughput I'm hoping for (ideally, maxing out the 40GbE, I would be using Jumbo Frames).
I generally prefer to use NFS for VMware as it's often handy been able to modify .vmx files etc, would NFS be a lot of overhead for this type of system, or should I be looking at iSCSI or something else entirely?
Any thoughts or feedback would be appreciated before we buy!
Cheers.
- X3550 M5 server (this supports up to 8 PCI cards)
 - 2x Xeon 8C E5-2630v3 2.4GHz/1866MHz/20MB
 - 64GB RAM (32GB per CPU), DDR4
 - 6x Intel 1.2TB SSD 750 Series (hence the need for a lot of PCI slots)
 - Mellanox ConnectX-3 Pro ML2 2x40GbE/FDR VPI Adapter
Cheers.
