W2K8R2 Active Directory / 9.2.1.6 winbindd idmap range not specified
Ed Hornsey
Looks a bit odd to me.
AD domain is webheath.local
All settings in Freenas point to a DNS resolvable AD server running all services.
Freenas message says
Jul  7 07:55:33 freenas winbindd[17938]:  STATUS=daemon 'winbindd' finished starting up and ready to serve connectionsidmap range not specified for domain FREENAS
Why would the server be looking for a domain called Freenas?
Ed Hornsey
Only jail running is MySQL.
Hostname is freenas.webheath.local
Results from /usr/var/local/smb4.conf
[global]
    server max protocol = SMB3
    encrypt passwords = yes
    dns proxy = no
    strict locking = no
    oplocks = yes
    deadtime = 15
    max log size = 51200
    max open files = 11070
    load printers = no
    printing = bsd
    printcap name = /dev/null
    disable spoolss = yes
    getwd cache = yes
    guest account = nobody
    map to guest = Bad User
    obey pam restrictions = Yes
    directory name cache size = 0
    kernel change notify = no
    ea support = yes
    store dos attributes = yes
    acl allow execute always = true
    idmap config *:backend = tdb
    idmap config *:range = 90000000-100000000
    server role = member server
    netbios name = FREENAS
    workgroup = WEBHEATH
    realm = WEBHEATH.LOCAL
    security = ADS
    client use spnego = yes
    cache directory = /var/tmp/.cache/.samba
    local master = no
    domain master = no
    preferred master = no
    acl check permissions = true
    acl map full control = true
    dos filemode = yes
    winbind cache time = 7200
    winbind offline logon = yes
    winbind enum users = yes
    winbind enum groups = yes
    winbind nested groups = yes
    winbind use default domain = yes
    winbind refresh tickets = yes
    idmap config webheath: backend = rid
    idmap config webheath: range = 20000-20000000
    allow trusted domains = no
    template shell = /bin/sh
    template homedir = /home/%U
    pid directory = /var/run/samba
    smb passwd file = /var/etc/private/smbpasswd
    private dir = /var/etc/private
    create mask = 0666
    directory mask = 0777
    client ntlmv2 auth = yes
    dos charset = CP437
    unix charset = UTF-8
    log level = 1
    acl check permissions = No
anodos
Sambassador
My best guess is that samba is trying to use the network interface for your jail. It's a promiscuous little bugger. If you stop your MySQL jail does the problem go away? Does the problem persist in 9.2.1.8? From a Windows workstation run "nbtstat -A [IP of FreeNAS server]"
Try setting the "interfaces" parameter for smb.conf in the "auxiliary parameters" field of your CIFS config. For proper syntax see here: https://www.samba.org/samba/docs/man/manpages-3/smb.conf.5.html#INTERFACES
Ed Hornsey
Hi anodos - your suggestion worked - thank you.:)
interfaces = <ip of server> in the auxilliary parameters for cifs.
