Volume Issues after Rename VGs
radw62
Hello FreeNFS comunity support
I know that is forum was created by FreeNAS, but Openfiler forum isnt active and I didnt find the help I need about this issue. Sorry.
In openfiler, I rename 2 VGs with vgrename and after the volumes with lvrename and editing the /opt/openfiler/etc/volumes.xml with the new names. Now, vmware ESXi dont find the iSCSI volumes conected and Openfiler shows only the iSCSI targets volumes, but unmapped.
What I want is recover ASAP the VM inside this VG , reconnecting it to ESXI, or at least all their VM files to rebuild it again in ESXi , hopefully using this time FreeNAS as iSCSI SAN.
Regards.
m0nkey_
Sorry, you're in the wrong forum. You're unlikely to get any help here. FreeNAS uses ZFS, not LVM.
