elangley
- Jun 4, 2012
Hello All,
In FreeNAS 11.1 I am attempting to create zpools/volumes on two identical systems that are running in VMware. They both exhibit that same symptoms. Here's the setup.
1 - 100 GB SSD disk configured as a ZIL
2 - 5 TB spinning disks configure as mirrors
Once I set these up in the Volume Manager and click Create Volume the status bar just keeps going and the zpool/volume is not created.
If close out the status bar the Volumes screen just says "Loading..."
I have about six FreeNAS systems (mostly 9.10.2U6) configured similarly, this is the only one with a volume creation issue.
What can I look for to troubleshoot?
~eric
~eric
