Hello friends, I am trying to resolve this problem for hours, but it looks out it's out of my scope.
I've updated my network to 10gbe recently and from that point, my jails lost network access.
I did iocage clean -a, to start fresh. but that didn't help.
I can't make new jail using vnet with working network. I can ping server, but can't ping gateway.
Jails have internet access if they are created without vnet option.
Plugins are failing on installation with message:
Error: plex had a failure Exception: RuntimeError Message: pkg.FreeBSD.org could not be reached via DNS, check plex's network configuration Partial plugin destroyed
I guess it's connected with vnet not working...
Please see my server and jails configuration below, hope somebody more skillful can help me out :) Tnx
On the server ifconfig -a
On the server netstat -rn
In the jail ifconfig -a
in the jail netstat -rn
iocoage get all test1
igb0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=e527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether d0:50:99:d0:06:ee
media: Ethernet autoselect
status: no carrier
nd6 options=1<PERFORMNUD>
em0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=81249b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,LRO,WOL_MAGIC,VLAN_HWFILTER>
ether d0:50:99:d0:06:ef
status: no carrier
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x4
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
ether 02:c5:a1:da:99:00
maxage 20 holdcnt 6 proto stp-rstp maxaddr 2000 timeout 1200
member: vnet0.2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 7 priority 128 path cost 2000
member: aq0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 2000
groups: bridge
vnet0.2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: test1 as nic: epair0b
options=8<VLAN_MTU>
ether f2:2f:74:35:09:16
hwaddr 02:79:64:79:57:0a
groups: epair
status: active
Internet: Destination Gateway Flags Netif Expire default 192.168.1.1 UGS aq0 127.0.0.1 link#4 UH lo0 192.168.1.0/24 link#1 U aq0 192.168.1.10 link#1 UHS lo0 Internet6: Destination Gateway Flags Netif Expire ::/96 ::1 UGRS lo0 ::1 link#4 UH lo0 ::ffff:0.0.0.0/96 ::1 UGRS lo0 fe80::/10 ::1 UGRS lo0 fe80::%lo0/64 link#4 U lo0 fe80::1%lo0 link#4 UHS lo0 ff02::/16 ::1 UGRS lo0
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
groups: pflog
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether f2:2f:74:35:09:17
hwaddr 02:79:64:79:57:0b
inet 192.168.1.20 netmask 0xffffff00 broadcast 192.168.1.255
groups: epair
status: active
nd6 options=1<PERFORMNUD>in the jail netstat -rn
Internet: Destination Gateway Flags Netif Expire default 192.168.1.1 UGS epair0b 127.0.0.1 link#1 UH lo0 192.168.1.0/24 link#3 U epair0b 192.168.1.20 link#3 UHS lo0 Internet6: Destination Gateway Flags Netif Expire ::/96 ::1 UGRS lo0 ::1 link#1 UH lo0 ::ffff:0.0.0.0/96 ::1 UGRS lo0 fe80::/10 ::1 UGRS lo0 fe80::%lo0/64 link#1 U lo0 fe80::1%lo0 link#1 UHS lo0 ff02::/16 ::1 UGRS lo0
CONFIG_VERSION:28 allow_chflags:0 allow_mlock:0 allow_mount:0 allow_mount_devfs:0 allow_mount_fusefs:0 allow_mount_nullfs:0 allow_mount_procfs:0 allow_mount_tmpfs:0 allow_mount_zfs:0 allow_quotas:0 allow_raw_sockets:1 allow_set_hostname:1 allow_socket_af:0 allow_sysvipc:0 allow_tun:0 allow_vmm:0 assign_localhost:0 available:readonly basejail:0 boot:0 bpf:0 children_max:0 cloned_release:12.2-RELEASE comment:none compression:lz4 compressratio:readonly coredumpsize:off count:1 cpuset:off cputime:off datasize:off dedup:off defaultrouter:192.168.1.1 defaultrouter6:auto depends:none devfs_ruleset:4 dhcp:0 enforce_statfs:2 exec_clean:1 exec_created:/usr/bin/true exec_fib:0 exec_jail_user:root exec_poststart:/usr/bin/true exec_poststop:/usr/bin/true exec_prestart:/usr/bin/true exec_prestop:/usr/bin/true exec_start:/bin/sh /etc/rc exec_stop:/bin/sh /etc/rc.shutdown exec_system_jail_user:0 exec_system_user:root exec_timeout:60 host_domainname:none host_hostname:test1 host_hostuuid:test1 host_time:1 hostid:00000000-0000-0000-0000-D05099D006EE hostid_strict_check:0 interfaces:vnet0:bridge0 ip4:new ip4_addr:vnet0|192.168.1.20/24 ip4_saddrsel:1 ip6:new ip6_addr:none ip6_saddrsel:1 ip_hostname:0 jail_zfs:0 jail_zfs_dataset:iocage/jails/test1/data jail_zfs_mountpoint:none last_started:2021-10-08 09:29:24 localhost_ip:none login_flags:-f root mac_prefix:f22f74 maxproc:off memorylocked:off memoryuse:off min_dyn_devfs_ruleset:1000 mount_devfs:1 mount_fdescfs:1 mount_linprocfs:0 mount_procfs:0 mountpoint:readonly msgqqueued:off msgqsize:off nat:0 nat_backend:ipfw nat_forwards:none nat_interface:none nat_prefix:172.16 nmsgq:off notes:none nsem:off nsemop:off nshm:off nthr:off openfiles:off origin:readonly owner:root pcpu:off plugin_name:none plugin_repository:none priority:99 pseudoterminals:off quota:none readbps:off readiops:off release:12.2-RELEASE-p10 reservation:none resolver:/etc/resolv.conf rlimits:off rtsold:0 securelevel:2 shmsize:off stacksize:off state:up stop_timeout:30 swapuse:off sync_state:none sync_target:none sync_tgt_zpool:none sysvmsg:new sysvsem:new sysvshm:new template:0 type:jail used:readonly vmemoryuse:off vnet:1 vnet0_mac:f22f74350916 f22f74350917 vnet0_mtu:auto vnet1_mac:none vnet1_mtu:auto vnet2_mac:none vnet2_mtu:auto vnet3_mac:none vnet3_mtu:auto vnet_default_interface:aq0 vnet_default_mtu:1500 vnet_interfaces:none wallclock:off writebps:off writeiops:off
