carloscerdaveloz
- Feb 2, 2022
Hello everyone
I am pretty new on NAS servers, I have just setup mine I couple days ago, but I am having issues with the internet connection on my system.
All my hardware specifications are at the end of my post.
ISSUE
I have installed the Plex plugin manually (the automatic system from the plugin store did not work, more about if later) wit the script here https://github.com/danb35/freenas-iocage-plex. I installed it on a jail with VNET configuration and static IP..
However, when I try to access the plex GUI using the IP it tells me that the connection is refused. At this point I can still ping from my free nas shell to google, i.e there is an Internet connection active.
To resolve this issue I have to do the next things:
- Stop the Jail -> Edit -> Select the interface from default to my interface -> accept changes -> and run the Jail again.
Now I have access to Plex, however... I do not have access to internet from the FreeNas GUI! Any ping will tell me No route to host.
Now to resolve it I can do the next:
- Go to the Network section on the FreeNas GUI -> Interfaces -> Edit -> Apply(No need to edit anything) -> Test changes -> accept changes.
Now I have internet on my freenas again but I lost access to the plex gui again!
Some information of what seems to be useful commands (based on other post here),
Note*: The jail is called pms
Note*: Freenas keeps the local connection, I can transfer and read files without any issues when plex is running
HARDWARE
AMD Athlon 3000g
Mainboard Asus Prime A320 M-K
Realtek® RTL8111H, 1 x Gigabit LAN Controller (Integrated)
Ram Corsair ddr4 3200 - 16gb
6 x 4tb ironwolf nas disks ST4000VN008
Router:
Deco S4
Access point (the server is connected to it) :
Archer a x20 tp link
Something about why I installed Plex using script!
The installation failed at 75%, after the steps "Starting Jail", after this point the nas losts connection to the internet and so the installation fails
ISSUE
root@truenas[~]# ifconfig
re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
ether fc:34:97:a1:6b:b5
inet 192.168.68.119 netmask 0xffffff00 broadcast 192.168.68.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
ether 02:fa:84:80:4d:00
maxage 20 holdcnt 6 proto stp-rstp maxaddr 2000 timeout 1200
member: vnet0.45 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 7 priority 128 path cost 2000
member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
groups: bridge
nd6 options=1<PERFORMNUD>
bridge1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 02:fa:84:80:4d:01
root id 00:00:00:00:00:00 priority 0 ifcost 0 port 0
groups: bridge
bridge2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 02:fa:84:80:4d:02
inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255
groups: bridge
vnet0.45: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: pms as nic: epair0b
options=8<VLAN_MTU>Code:
root@pms:~ # ifconfig
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
groups: pflog
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 06:49:65:57:7e:c1Code:
root@truenas[~]# iocage get all pms CONFIG_VERSION:28 allow_chflags:0 allow_mlock:0 allow_mount:0 allow_mount_devfs:0 allow_mount_fusefs:0 allow_mount_nullfs:0 allow_mount_procfs:0 allow_mount_tmpfs:0 allow_mount_zfs:0 allow_quotas:0 allow_raw_sockets:0 allow_set_hostname:1 allow_socket_af:0 allow_sysvipc:0 allow_tun:0 allow_vmm:0 assign_localhost:0 available:readonly basejail:1 boot:1 bpf:1 children_max:0 comment:none compression:lz4 compressratio:readonly coredumpsize:off count:1 cpuset:off cputime:off datasize:off dedup:off defaultrouter:192.168.68.1 defaultrouter6:auto depends:none devfs_ruleset:4 dhcp:0 enforce_statfs:2 exec_clean:1 exec_created:/usr/bin/true exec_fib:0 exec_jail_user:root exec_poststart:/usr/bin/true exec_poststop:/usr/bin/true exec_prestart:/usr/bin/true exec_prestop:/usr/bin/true exec_start:/bin/sh /etc/rc exec_stop:/bin/sh /etc/rc.shutdown exec_system_jail_user:0 exec_system_user:root exec_timeout:60 host_domainname:none host_hostname:pms host_hostuuid:pms host_time:1 hostid:c59289ce-5f45-df2a-a82a-fc3497a16bb5 hostid_strict_check:0 interfaces:vnet0:bridge0 ip4:new ip4_addr:vnet0|192.168.68.175/24 ip4_saddrsel:1 ip6:new ip6_addr:none ip6_saddrsel:1 ip_hostname:0 jail_zfs:0 jail_zfs_dataset:iocage/jails/pms/data jail_zfs_mountpoint:none last_started:2022-02-02 03:00:35 localhost_ip:none login_flags:-f root mac_prefix:064965 maxproc:off memorylocked:off memoryuse:off min_dyn_devfs_ruleset:1000 mount_devfs:1 mount_fdescfs:1 mount_linprocfs:0 mount_procfs:0 mountpoint:readonly msgqqueued:off msgqsize:off nat:0 nat_backend:ipfw nat_forwards:none nat_interface:none nat_prefix:172.16 nmsgq:off notes:none nsem:off nsemop:off nshm:off nthr:off openfiles:off origin:readonly owner:root pcpu:off plugin_name:none plugin_repository:none priority:99 pseudoterminals:off quota:none readbps:off readiops:off release:12.2-RELEASE-p13 reservation:none resolver:/etc/resolv.conf rlimits:off rtsold:0 securelevel:2 shmsize:off stacksize:off state:up stop_timeout:30 swapuse:off sync_state:none sync_target:none sync_tgt_zpool:none sysvmsg:new sysvsem:new sysvshm:new template:0 type:jail used:readonly vmemoryuse:off vnet:1 vnet0_mac:064965577ec0 064965577ec1 vnet0_mtu:auto vnet1_mac:none vnet1_mtu:auto vnet2_mac:none vnet2_mtu:auto vnet3_mac:none vnet3_mtu:auto vnet_default_interface:au vnet2_mac:none vnet2_mtu:auto vnet3_mac:none vnet3_mtu:auto vnet_default_interface:auto vnet_default_mtu:1500 vnet_interfaces:none wallclock:off writebps:off vnet3_mtu:auto vnet_default_interface:auto vnet_default_mtu:1500 vnet_interfaces:none wallclock:off writebps:off writeiops:off
root@truenas[~]# netstat -rn Routing tables Internet: Destination Gateway Flags Netif Expire 0.0.0.0/8 link#5 U bridge2 127.0.0.1 lo0 UHS lo0 192.168.68.0/24 link#1 U re0 192.168.68.119 link#1 UHS lo0 Internet6: Destination Gateway Flags NetifExpire ::/96 ::1 UGRS lo0 ::1 lo0 UHS lo0 ::ffff:0.0.0.0/96 ::1 UGRS lo0 fe80::/10 ::1 UGRS lo0 fe80::%lo0/64 link#2 U lo0 fe80::1%lo0 link#2 UHS lo0 ff02::/16 ::1 UGRS lo0 root@truenas[~]#
root@pms:~ # netstat -rn Routing tables Internet: Destination Gateway Flags Netif Expire default 192.168.68.1 UGS epair0b 127.0.0.1 link#1 UH lo0 192.168.68.0/24 link#3 U epair0b 192.168.68.175 link#3 UHS lo0 Internet6: Destination Gateway Flags NetifExpire ::/96 ::1 UGRS lo0 ::1 link#1 UH lo0 ::ffff:0.0.0.0/96 ::1 UGRS lo0 fe80::/10 ::1 UGRS lo0 fe80::%lo0/64 link#1 U lo0 FreeBSD directory layout: man hier Edit /etc/motd to change this login announcement. root@pms:~ # netstat -rn Routing tables Internet: Destination Gateway Flags Netif Expire default 192.168.68.1 UGS epair0b 127.0.0.1 link#1 UH lo0 192.168.68.0/24 link#3 U epair0b 192.168.68.175 link#3 UHS lo0 Internet6: Destination Gateway Flags NetifExpire ::/96 ::1 UGRS lo0 ::1 link#1 UH lo0 ::ffff:0.0.0.0/96 ::1 UGRS lo0 fe80::/10 ::1 UGRS lo0 fe80::%lo0/64 link#1 U lo0 fe80::1%lo0 link#1 UHS lo0 ff02::/16 ::1 UGRS lo0 root@pms:~ #
HARDWARE
AMD Athlon 3000g
Router:
Deco S4
