VNC disconnect after installing virto drivers.
OskOskOsk
When im trying to install Windows Server 2019 Standard Evaluation after choosing load driver (virtio win 1.208)(D:\amd64\w10\viostor.inf) vnc disconnect. How can i fix this?
Version: TrueNAS-12.0-U6.1.
Intel(R) Xeon(R) CPU E5-2650 v3 @ 2.30GHz
Patrick M. Hausen
Try to set the block size of the virtual didk device to 512.
Victore
Hi There,
Same problem here.
Create VM for Windows 10
Set disk to 512
start VM + VNC
load Virtio driver
Windows 10 Pro
when install starts VNC disconnect?
I can't find a solution, perhaps in another tread.
Can enyone help me out?
Thanks in advance.
RogueSI
Used Virtio-win-0.1.229 to get past the driver/install crashing boss. Hope this helps someone looking at a dead thread!
