gudvin.dll
- Jul 12, 2017
I create ubuntu vm on FreeNAS-11.3-U3.1 and i have a problem
VM's network is not working. I can connect to vm from VNC , but in vm i don't have network.
in virtual ubuntu i have one interface lo
if edit /etc/network/interfaces
and
sudo ifconfig enp0s4 up
in settings ubuntu VM i create NIC interface
in network interfaces i have only re0
But if i run
sudo ip addr add 192.168.10.128/24 dev enp0s4
and
network working until reboot server
root@freenas[~]# ifconfig -a re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether e0:d5:5e:e6:b3:e8 hwaddr e0:d5:5e:e6:b3:e8 inet 192.168.10.101 netmask 0xffffff00 broadcast 192.168.10.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:4a:06:89:7c:00 nd6 options=9<PERFORMNUD,IFDISABLED> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 5 priority 128 path cost 2000000 member: vnet0.1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 4 priority 128 path cost 2000 member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 vnet0.1: flags=8942<BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: torrents as nic: epair0b options=8<VLAN_MTU> ether e2:d5:5e:5b:d5:71 hwaddr 02:76:d0:00:04:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: Attached to ubuntu options=80000<LINKSTATE> ether 00:bd:33:8d:35:00 hwaddr 00:bd:33:8d:35:00 nd6 options=1<PERFORMNUD> media: Ethernet autoselect status: active groups: tap Opened by PID 26901
auto enp0s4 iface enp0s4 inet dhcp
and
But if i run
and
