BlinkyBill
- Nov 2, 2015
I'm running an Ubuntu VM on TrueNAS Core version TrueNAS-12.0-U7, in which I run a number of docker containers. I was unable to connect to some of the docker containers, and when I logged into the VM I received a "No Space left on device" when writing to a log error message.
When I run the df -h command I get the following:
I don't recall setting any system space parameters when I set up the VM, so how can I fix this space constraint issue?
Thank you
Thank you
