Virtual Machine taking up space even after delted.
IzLogan
I have created a few Virtual Machines and of large capacity but i have deleted them but the storage needed for the Virtual Machines are still being used up.
The Disk image is supposed to be located at "/mnt/ada01pool/iocage" and i go there but cannot find any one of them (Logged in as root), and ive checked in "/mnt/ada01pool/iocage/images" and they aren't there either.
Patrick M. Hausen
The disk images are ZVOLS - block devices, they are not visible in the filesysten. Navigate to Storage --> Pools in the UI and you will find them by expanding the list. You can delete them from the UI.
HTH,
Patrick
IzLogan
HTH,
Patrick
Oh Okay thank you that helps alot!
