View of filesystem without duplicated directories mounts?
IanWorthington
I'm looking to find duplicate files on my zfs volume to delete using hashdeep (plus my own analysis program).
One issue I'm facing is that as I mount directories from that volume into, for example, the plexmediaserver jail, which is also on that same volume, then a recursive hashdeep of /mnt/volume1 will return those files twice.
Is there any alternative directory view of the entire volume which will allow me to access a unique list of all the files on the system?
Ian
SweetAndLow
Sweet'NASty
Don't run the program from the root dataset. This way it won't include your jails dataset.
depasseg
FreeNAS Replicant
Can you just exclude the jails subfolders from analysis?
I can't think of a way to do this without unmounting the jails dataset. And I think that the only place where this will come up is the jails.
