View Disk show no Disk
Scott B
I have searched the forum and have found multiple posting about this subject but they have dealt with initial configuration setup that indicate the disk are not being found during installation or boot up. My situation is a bit different. I have inherited a FreeNAS environment with no previous knowledge and no documentation from the person I replaced.
Our environment is online and functioning with no issues. We have one drive showing failed in the View Multipaths selection. However, the View Disks option does not show any disks listed. Also, the individual that set the system up did not document serial numbers for the hard drives or for that matter any documentation at all regarding the system. I know I can power down the unit and get the serial numbers which I have scheduled. However, if the disk do not show in the View Disk section I do not have a way that I have been able to find to determine which disk is the defective one.
Build: FreeNAS-9.3-STABLE-201605170422
If you need additional information related to our system please, let me know.
I apologize if this needed to be posted in a different forum as I am a newbie with FreeNAS.
Thank you
Scott B
[root@bizzarro ~]# zpool status
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0h0m with 0 errors on Wed May 17 03:45:42 2017
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
mirror-0 ONLINE 0 0 0 ada0p2 ONLINE 0 0 0 ada1p2 ONLINE 0 0 0
errors: No known data errors
pool: secondary
state: ONLINE scan: scrub repaired 0 in 11h18m with 0 errors on Sun May 7 11:18:23 2017
secondary ONLINE 0 0 0
raidz3-0 ONLINE 0 0 0
gptid/27a0f20e-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
gptid/284ef222-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
gptid/2902c4a6-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
gptid/29ac0ca6-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
gptid/2a4dc5c0-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
gptid/2af36042-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
gptid/2b9ec817-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
raidz3-1 ONLINE 0 0 0
gptid/2c41f8e4-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
gptid/2cf2b457-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
gptid/2d978088-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
gptid/2e3fbf6b-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
gptid/2ef0d035-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
gptid/2f9c5635-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
gptid/30513b25-af21-11e5-95ed-00259065f9e4 ONLINE 0 0 0
D
dlavigne
Guest
Were you able to resolve this? If not, does updating to 11.0 fix it?
Scott B
No, I have not been able to resolve yet. I have not updated as if possible I would like to get the drives replaced before adding anything new to the environment.
Thank you
