Hazimil
- May 26, 2014
Hi
I plan to use rclone to backup my NAS to B2 (had enough of CrashPlan), and as I want to adjust some of the parameters of rclone I cannot use the GUI Cloud Sync Tasks. Therefore I am writing a script to run as a cron job.
I've noticed that even though I have setup B2 within Cloud Credentials, running rclone config from the CLI of the FreeNAS server I get:
As I'm wary of making any changes within the FreeNAS base O/S, would it be recommended to create a simple Jail with mounts to run rclone from?
Just after peoples views/ideas on this.
Yours
Jonathan
# rclone config 2019/06/05 18:26:21 NOTICE: Config file "/root/.config/rclone/rclone.conf" not found - using defaults No remotes found - make a new one n) New remote s) Set configuration password q) Quit config n/s/q> q
Yours
Jonathan
