Using a disk slice
Crispin
Member
Hi Folks,
My home setup is 5 2TB disks with 2 SSDs for cache ZIL.
What I have done in the past on Solaris is partition the SSDs to 50/5GB and use the 5GB slices as a mirrored ZIL and the 50s as cache.
This option, while not perfectly ideal (shared disk an' all that) works brilliantly and speed improvement is well worth it. (on current sol NAS I can write at 600MB/s and read about 450).
I have done the same with FreeNAS but through shell and ZFS seems to like it however, the GUI does not see that these disks are used up. Is there there some way to "sync" the GUI with changes I have made to the pool?
Thanks
Crispin
etrai
Newbie
I'm having the same sort of unorthodox setup and the GUI finds one of my two storage pools (5 disks total, larger striped volume across all drives and a smaller RAID-Z across three of the drives). CLI works nicely but changes are only persisted until reboot and not visible in the GUI.
Is there a workaround to make the changes I make with CLI permanent until the feature is implemented in FN8? It was there in FN7.
