User Permissions: read/write to ONLY their own dataset via ssh
martin2380
I'm evaluating Truenas Scale as my ransomware-secure Backup Box.
The Box will only be accessible via SSH and is physically in an other Location.
I would prefer that the Backup Server is pulling the Backups from the Clients - but there are a few Machines that won't be accessible from outside. For them, i will provide a ssh user for every Client Machine that only should have access to their dedicated dataset.
I was able to do that by setting the owner of the datasets to the client-user and disabling read/write/execute for "others".
But the client users still have read access to directories /etc, /var etc.
tl;dr:
I want a user "client1" with ssh credentials have read/write access to only the dataset /mnt/tank/client1, without having any rights for other directorys.
Is it possible to disable even read rights to that direcotrys for client users?
Best Regards
Martin
anodos
Sambassador
If they only need to read / write files, then you can probably create a sftp chroot for them via auxiliary parameters in the ssh config. Some care will be needed in setting it up so that your users / groups / permissions are correct (and also that you don't break SSH access), but in principle it shouldn't be different than doing the same on a plain linux server.
martin2380
I will try this later. But as far as i know, rsync requires an actual shell. Won't the shell be able to cd into other directorys?
