SOLVED Use jail to Nat traffic from VPN to specific machine
Grinas
Hey,
So i have a machine on my network that i have limited control over this VNC machine only allows access to it on its local subnet. The problem is when im out and about i can access my environment over VPN but i can not access this.
I want to be able to configure a jail to Nat the connect to the machine so the VNC machine thinks the traffic is coming from my local network and not my VPN network. the only port i really needed NAT'd is vnc port 5900
so here is what i am trying to achieve using info i found on other threads
Vpn network 10.99.8.0/24 ---> Jail 192.168.0.63 Nat traffic ---> VNC Machines 192.168.0.85
I have tired messing out with the IPFW rules but so far had no joy.
here is what i have i my /etc/rc.conf
# Enable Firewall
firewall_enable="YES"
firewall_script="/usr/local/etc/ipfw.rules"
and here is the contents of /usr/local/etc/ipfw.rules
#!/bin/sh
ipfw -q -f flush
ipfw add 100 nat 500 ip4 from 10.99.8.0/24 to 192.168.0.85 out via epair0b
ipfw add 101 nat 501 ip4 from any to any in via epair0b
any help would be much appreciated.
Sounds like you could just run nginx and reverse proxy a TCP stream of port 5900...
Grinas
is it not possible to do this with IPFW so?
If you search the forum for IPFW, you'll probably find a bunch of posts saying that it's not a good idea to use IPFW. I agree with those.
A reverse proxy will do the job well.
Your nginx config would be as simple as:
stream {
  upstream vncserver {
    server 10.0.0.1:5900;
  server {
     listen      5900;
     proxy pass vncserver;
Grinas
i wasnt aware of that.
I managed to figure out how to do it with my firewall it was a lot easier than i expected in the end.
Thanks for the help.
