I am trying to get a Aeotec Z-Stick Gen5 stick to work on Domoticz in an iocage jail.
The device is recognized in freenas as
If I understand correctly I have to unhide the device in
When I run
This indicates that the rules are set correctly.
In the freenas GUI I set the
When I start the jail from the commandline I get the warning
The device is not visible so it seems that my custom rules are not being used. Some say that you have to add the following to
But this also doesn't work, I also added it to my init script so that it is always added after reboot, but it still doesn't work.
The strange thing is, when I set the
Does anyone have an idea why this doesn't work? All the documentation shows that this is the way it should work, add a custom ruleset and make sure the jail uses that ruleset. But it seems that my custom rules are unknown to the iocage jail.
/dev/cuaU0, but is not visible in the jail.If I understand correctly I have to unhide the device in
/etc/devfs.rules. Since this file gets overwritten after each reboot I added the following script which runs at postinit:Code:
#!/bin/sh cat >>/etc/devfs.rules << 'EOF' [devfsrules_common=44] add include $devfsrules_hide_all add include $devfsrules_unhide_basic add include $devfsrules_unhide_login add include $devfsrules_jail add path 'cua*' unhide EOF service devfs restart
When I run
devfs rule -s 44 show I get the following output:Code:
100 include 1 200 include 2 300 include 3 400 include 4 500 path cua* unhide
devfs_ruleset to 44, this is the id of my custom ruleset. I also enabled mount_devfs, allow_mount and allow_mount_devfs.When I start the jail from the commandline I get the warning
Domoticz is not using the devfs_ruleset of 4, not generating a ruleset for the jail, DHCP may not work.The device is not visible so it seems that my custom rules are not being used. Some say that you have to add the following to
/etc/rc.conf :Code:
devfs_enable="YES" devfs_system_ruleset="devfsrules_common"
devfs_ruleset to 3 (1 to 4 are default rules defined in /etc/defaults/devfs.rules) which exposes all devices to the jail I can see my device just fine and can use it in Domoticz, but now all other devices are visible too in my jail.Does anyone have an idea why this doesn't work? All the documentation shows that this is the way it should work, add a custom ruleset and make sure the jail uses that ruleset. But it seems that my custom rules are unknown to the iocage jail.
