I have installed the jail succesfully (I think), now I am uploading a plugin, but when the upload proces bar appears , it suddenly disappears again and "an error occured" shows up.
This shows up down below:
Jun 26 20:58:11 freenas notifier: mkdir: archive: Read-only file system
Jun 26 20:58:11 freenas notifier: chown: archive/.freenas: No such file or directory
Jun 26 20:58:11 freenas notifier: chmod: archive/.freenas: No such file or directory
Jun 26 20:58:11 freenas notifier: ln: /var/tmp/firmware: No such file or directory
Probably something simple, but I would appreciate the help.
EDIT:
dmesg:
da0: 3843MB (7870464 512 byte sectors: 255H 63S/T 489C) cd0 at ahcich1 bus 0 scbus1 target 0 lun 0 cd0: <MATSHITA DVD-RAM UJ890AS 1.00> Removable CD-ROM SCSI-0 device cd0: 150.000MB/s transfers (SATA 1.x, UDMA5, ATAPI 12bytes, PIO 8192bytes) cd0: Attempt to query device size failed: NOT READY, Medium not present - tray c losed GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s). Trying to mount root from ufs:/dev/ufs/FreeNASs1a WARNING: /data was not properly dismounted GEOM_ELI: Device ada0p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: software ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present; to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf. ZFS filesystem version 5 ZFS storage pool version 28 bridge0: Ethernet address: 02:29:27:99:f1:00 epair0a: Ethernet address: 02:00:c2:00:0b:0a epair0b: Ethernet address: 02:00:c2:00:0c:0b epair0a: link state changed to UP epair0b: link state changed to UP epair0a: promiscuous mode enabled alc0: promiscuous mode enabled [root@freenas ~]#
EDIT:
dmesg:
