upgrading motherboard...
SirLars
So I started my freenas with a project I purchased used. I purchased a server that was set up as a NAS STUFFED with 9 - 750gb hdd and 4gb ram. I upgraded the ram to the max supported by the board 8gb and changed 5 of the 750gb hdd with 4- 3tb wd red drives and installed freenas with two ZFS pools (the 4-750gb drives in one pool for about 1.8tb and the 4-3tb drives in another pool with about 10.1 tb) the OS is on a 16gb usb 3.0 stick.
It was amazingly fast at first, and so handy having all of my data on one server, easily accessed anywhere I wanted. I loved it!
However now that it is filling up (about 400GB on Volume 1 and 6.5 tb on Volume 2) I can tell the RAM is not enough as it has gotten much slower and I am getting heat warnings... I add about 50-100 GB per week, so I dont have long before it becomes unusable...
I am considering replacing the other 4- 750gb hdd with 4 more 3tb or 4tb wd red drives, but there is no way the current mobo / ram setup can support that as it's RAM is already maxed out.
This is a home NAS with mostly media and my home computer backups on it.
I want to re-purpose this server so I am purchasing a new case with better airflow, 8 sata port mobo, 24-32GB ram, and 4 more 3tb wd red drives. Obviously I want to save the data on the old NAS...
My questions as I am still kind of new to this;
What is the best method for retaining my data, but rebuilding the NAS to use the 8 wd drives on the new motherboard and case and ram.
I was considering building the new NAS with the 4 new drives, copying the data from the old NAS to the new NAS, then erasing the old drives and adding them to the new one as a second pool... is there a better method that won't take days to copy over?
and hardware wise, do I really NEED a Xeon processor, server board and ECC RAM? it seems much more cost effective to use a decent AMD am3+ board, 6 or 8 core processor and 32gb of DDR3 than going with server grade hardware and ECC ram. Considering this is a home setup, not mission critical data and performance isn't as important as "upgradability" and cost effectiveness...
looks like almost $1000 difference...
$964.91
https://secure.newegg.ca/WishList/MySavedWishDetail.aspx?ID=31703728
1,924.87
https://secure.newegg.ca/WishList/MySavedWishDetail.aspx?ID=31703688
any help would be appreciated.
You could just pull the drives out of the old machine and put them in the new one. Poof, instant upgrade.
JohnK
hmm, can't seem to see those wish lists..
I didn't look at your wish lists, but I got my motherboard, CPU, and RAM for less than $1000 total...
Supermicro X9SCM-F ($160)
Xeon E3-1230V2 ($235)
32GB of ECC RAM ($400)
Where are you getting the idea there's $1000 difference?
And please don't post wish lists. They'll expire and nobody will ever be able to look at your build after that.
JohnK
and if you are on a tight budget and are willing to hop around it is closer to $550, no Xeon though.
SUPERMICRO X10SLM-F ($135)
DDR3-1600 32GB ($345)
Pentium G3420 3.20 GHz ($72)
SirLars
Thanks, for the response, especially about just moving the HDDs over, that will definitely save some time. Do I just take the USB stick from the current NAS and use it to keep my settings? or do I need to install it again to a new USB drive, and then add the drives and the data will be recognized and available.
re: Hardware wishlists. I made them public, not sure why they cant' be seen. I checked and the actual difference was about $450 (I was missing 3 drives in the first one), mostly in the RAM and motherboard and 100$ for the recommended sata card on e-bay.
Using the recommendations in your signature, I made this new list
SUPERMICRO MBD-X9SCA-F-O LGA 1155 Intel C204 ATX Intel Xeon E3 Server Motherboard
209.99
Supermicro X9SCM-F ($160) is not available on Newegg.ca
Intel Xeon E3-1230 V2 Ivy Bridge 3.3GHz (3.7GHz Turbo) LGA 1155 69W Quad-Core Server Processor BX80637E31230V2
239.99 (lowest price 69W cpu I could find)
Kingston 8GB 240-Pin DDR3 SDRAM DDR3 1600 ECC Unbuffered Server Memory w/TS Intel Model KVR16E11/8I
4x 108.49 =
433.96
total =
883.94
plus I will need to add (again, according to your hardware recommendation link) to get 8 sata ports...
IBM ServeRAID M1015
approx $125 on eBay
http://www.ebay.ca/sch/i.html?_nkw=ServeRAID+M1015+-key
for total of around $1000.00 (plus case, psu and drives)
(the savings using AMD 6 core
AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W Six-Core Desktop Processor FD6300WMHKBOX @$125
and motherboard
ASRock 990FX Extreme4 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard @ $
154.99
and memory
Crucial Ballistix Sport 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory Model BLS8G3D1609ES2LX0 @ 4x 74.99 =
279.96
for total of
559.94 (plus case, psu and drives)
is there another "cheaper" recommendation for sata controller?
I could probably just use the sata controllers in my current setup, I know they work on this system, but have no idea if they will work on the xeon board,
I am not sure if they are optimal. I think they are cheapo 2 port units. I can't make out the model.
I suppose, for $440 difference (330 if I re-use my sata controllers), that isn't a totally bad idea... there would be some saving in electricity and a definite increase in reliability.
Thanks.
JohnK
I have seen ppl recommending the SUPERMICRO MBD-X10SL7-F-O uATX Server Motherboard LGA 1150 Intel C222 DDR3 1600 ($260)
Saves you from getting the M1015.
Also note that these "Xeon" boards can take both i3 and Pentiums.
SirLars
Thanks for that mobo recommendation, I am definitely going for that.
I was concerned that the i3 processors didn't support ECC?
I figured, if I didn't use an ECC supported processor, wouldn't that remove the necessity of the ECC RAM and mobo?
I don't see ECC support on the newegg site for any of the "desktop grade" 1155 chipset cpus.
I would happily use an i3 if I can still get the benefit of ECC for half the price.
warri
The board JohnK recommended uses sockel LGA 1150 (not 1155).
Haswell i3's (4th gen) have ECC support: Intel ARK. In fact even the cheaper Pentium G's support ECC.
