Jellis1976
 - Aug 20, 2016
I have an older version 9.2.1.7  64 bit version and would like to upgrade to 9.10. However the OS drive it is currently on is a 4gb Flash drive.  It now states it recommends 8gb for the new Version. I need to know which is the best version to not loose all my information on the hard drives.  I do have more than 8gb of ram and they are set up in raid 5 ZFS.
So the issue I am facing is doing one of two options:
1. Clone the first drive onto a new 8 gb flash drive and then upgrade to 9.3.1 then to 9.10
2. Install 9.10 directly on the 8gb Flash drive.
If I use either option will the information on the drives be lost. I currently have 4 tb worth of data and currently no other place to store this information to back it up.
