I have been running FreeNAS 8.0.4 for quite a while with just a few issues.
It is running as a Virtual Appliance on and ESXi 5.0 server with RDMs allocated to the the VA using ZFS.
I originally allocated 10Gb as a virtual disk with 4092MB virtual memory.
I have since upgraded to the 8.2.0 version, and increased the virtual memory to 5120 MB, but I have had quite a few issues.
Firstly I am now getting the following error:
pid 1611 (sed), uid 0 inumber 731 on /etc: filesystem full.
Below output of "df -k"
Filesystem 1024-blocks Used Avail Capacity Mounted on
/dev/ufs/FreeNASs1a 948903 361825 511166 41% /
devfs 1 1 0 100% /dev
/dev/md0 4663 4624 -333 108% /etc
/dev/md1 823 2 756 0% /mnt
/dev/md2 152791 7644 132924 5% /var
/dev/ufs/FreeNASs4 20263 759 17883 4% /data
data 11436649680 1633890849 9802758831 14% /mnt/data
NOTICE /dev/md0 above.
I have increased the virtual disk to 20Gb now, but I do not want to modify any slices until I can identify the actual issue.
I can connect using the web services, but have since noticed that once in a while I have to restart my CIFS service to re-establish connections to my shares.
I have even backed up my config and re-installed from scratch, but on uploading my backup the same problem arose.
Any help or advise would be much appreciated.
thanks
Stephen
thanks
Stephen
