Upgrade Stuck on "Writing new firmware"
Zythyr
My GUI upgrade from 9.2.1.3 to 9.2.1.5, is stuck on " (3/3) Writing new firmware". It's been stuck on 67% for a long time... What should I do?
D
dlavigne
Guest
If it stayed stuck, open a ticket at bugs.freenas.org and post the issue number here.
In the mean time as a work-around, you can still make a backup of the config and do a fresh install.
duk242
I had the same issue, I left it for a couple hours and then just closed the Window and rebooted the server. It came back up alright and says it's running 9.2.1.5 so I guess it went okay....
Of course, I'm ready to revert the changes and restore from backup if there's any issues...
habbers
I experienced exactly the same issue when upgrading from 9.2.1.2 and left it for 30 minutes at 67% before reloading the page and then rebooting the server. After the reboot it shows that it is running 9.2.1.5 and I haven't noticed any other issues yet.
