aDigitalPhantom
- Nov 21, 2017
I started using FreeNAS back around 0.6.9, or 0.7.0. With each new version it's become less, and less stable for me. About 6 months ago I had a storage drive fail, and I replaced it. Since then the OS has not started. Fixing it hasn't been a high priority, and now it's finally to the point to be fixed. I think I was on 9.3, but I don't remember.
If I install the current stable version will it wipe the data on the software raid from before? Unfortunately I need to keep that data. The NAS was the primary backup device, and I was in the process of setting up a secondary backup when this happened. The files on it aren't accessed very often.
I've had to reinstall FreeNAS 3-4 times a year because it keeps corrupting itself somehow. The device it's on doesn't matter. in the old versions when I could use a CF2IDE adapter, and just write an image to it I had almost no problems. Now it doesn't matter if it's on a USB flash drive, a USB HDD/SSD, or an internal HDD/SSD the OS will be corrupt before 6 months. Has anything been done to correct this?
I've been trying to run some test using VirtualBox, and it insists there is no DHCP server on the network when there is. I'm also using two different versions of Ubuntu Server x64 for testing other things in the on the same system. The system it self has no problems getting it's IP from DHCP, the other virtual machines see the DHCP server and acquire an IP, but FreeNAS won't. The network config for all VMs is a bridged adapter set to allow all. The DHCP server is on the Linksys router running DD-WRT v3.0-r33772 mega. I'm guessing it's a FreeBSD or FreeNAS issue, but I'm not sure what I can do about it. I know I can use a static IP, but I have the network setup to have DHCP assign the static IPs because it removes needing to reconfigure each system when a change is made.
PS
It should be RAID 1+0 using 4 3TB Seagate drives. It was about 2/3 used when it was last running.
PS
