BarefootWoodworker
- Feb 22, 2017
I have a TrueNAS box (see signature) that I'm thinking of upgrading due to tax time and refund (yay!).
The choices are going from 128GB of RAM to 512GB of RAM or go from 10 2TB (8TB-ish of usable space) Red Pros to 10 6 TB (guesstimating around 24TB-ish of usable space) Red Plus drives (I may go with 12 of them, depends on how I feel). The main issue is that I know if I go with the expanded space, the memory should probably be expanded as well. I'm just not completely sure of the "rule of thumb" calculation for pool size vs memory.
The 6TB drives are also 5400RPM vs the 2TB 7200RPM (they're both CMR, though).
It's getting slightly over that 50% very loose general rule of thumb for usage, so I'm curious what's going to be the best "bang for the buck", so to say so that I don't lose the very nice speeds and stability I have going on currently.
TIA
TIA
