tartan-prophesy
- Mar 7, 2022
I've been running a FreeNAS system for a long time and it's due an upgrade. I mainly manage a lot of media with the system using a lot of jails. I also have a VM running for Roon and a few jails for home automation / Gitlab.
The current system is:
Some advice for what to do would be really appreciated.
Thanks
- 16GB of RAM
- Pentium G3220 @ 3.00GHz
- 6x Hitachi 4TB 5400RPM SATA (HDS5C4040ALE630) in RAIDZ2
- Fractal Design Node 304
- Seasonic 400W platinum PSU
- ASRock E3C224D2I motherboard
- USB thumb drive for booting
- Keep the discs, but have an upgrade path to double the capacity (maybe more... who knows what the future will bring)
- Add a proper boot drive
- Add an l2arc
- Stick much more RAM in, I think 16GB is simply not enough
- Use my existing rack, this can only accomodate gear that is upto ~45cm deep. I was thinking a 3u case would be ideal
- Upgrade the CPU and motherboard to support all of the above
Thanks
