Updating V11 to V11 U3
bellmr
I keep having an error when trying to update from V11 to V11 U3. The error is a missing test_argparse.py file in the tmp directory that is created, and this is the gist of it :
[MiddlewareError: b"[Errno 2] No such file or directory: '/tmp/tmpmdtfxiji/usr/local/lib/python2.7/test/test_argparse.py' -> '/tmp/tmpmdtfxiji/usr/local/lib/python2.7/test/test_argparse.py.old'"]
If I look in the tmp directory before this occurs, I can see the file, but when it bombs out, the folder tmpmd... (these namse change obviously with each attempt) is deleted.
Has anyone seen this as well, and if so, what is the solution?
Thanks in advance,
Malcolm Bell
D
dlavigne
Guest
Are you on the 11 STABLE train? If so, did you run a nightly at any point?
bellmr
Thanks for the prompt reply. I am on the stable train, and have never used a nighty update. I also tried using the manual update route, but it also bombed out, with a different error, the likes of which I didn't copy down.
D
dlavigne
Guest
In that case, please create a bug report at bugs.freenas.org that includes the complete error text of your latest attempt, and post the issue number here.
bellmr
I managed to get it to U3, by rebooting back in to a 9.10 instance, and then upgrading to U3 from there. I guess there was some problem with my V11-Release instance. Thanks for you input.
