EDIT: Changed to solved, I ended up buying a new usb stick and doing a clean install. The SaveConfiguration feature was causing several UnicodeDecode errors during bootup after importing the new configuration so had to redo the config by hand. Nevertheless, thanks for the help and suggestions!
In another thread I mentioned that i had a failure during my update process going from 9.3 to 9.3.1.
here is my update.failed output, can someone please give me an hand, I don't even know where to start.
I'm reverting back to my original boot now.
I'm also getting a this in my console:
ps: cannot mmap corefile
ps: empty file: Invalid argument
Running migrations for api:
- Nothing to migrate.
- Loading initial data for api.
Installed 0 object(s) from 0 fixture(s)
Running migrations for freeadmin:
- Loading initial data for freeadmin.
Running migrations for services:
- Migrating forwards to 0190_dup_webdav.
> storage:0051_auto__add_field_task_task_excludesystemdataset
> services:0156_auto__add_field_iscsitargetextent_iscsi_target_extent_blocksize__add_f
> services:0157_auto__del_field_iscsitarget_iscsi_target_logical_blocksize
> services:0158_auto__add_field_afp_afp_srv_homename
> services:0159_auto__add_field_nfs_nfs_srv_v4_krb
> services:0160_pwencrypt
- Migration 'services:0160_pwencrypt' is marked for no-dry-run.
> services:0161_auto__chg_field_cifs_cifs_srv_bindip
> services:0162_auto__add_field_iscsitargetextent_iscsi_target_extent_rpm
> services:0163_auto__add_field_ssh_ssh_host_dsa_key_cert_pub__add_field_ssh_ssh_host_
> services:0164_nfs_srv_v4_krb_fix
- Migration 'services:0164_nfs_srv_v4_krb_fix' is marked for no-dry-run.
> services:0165_auto__add_field_snmp_snmp_v3__add_field_snmp_snmp_v3_username__add_fie
> services:0165_fix_ddns_domains_delimiters
- Migration 'services:0165_fix_ddns_domains_delimiters' is marked for no-dry-run.
> services:0166_pwencrypt
- Migration 'services:0166_pwencrypt' is marked for no-dry-run.
> services:0167_auto__add_field_ups_ups_powerdown
> services:0168_snmp_v3_literal
- Migration 'services:0168_snmp_v3_literal' is marked for no-dry-run.
> services:0169_auto__add_field_iscsitargetportal_iscsi_target_portal_discoveryauthmet
> services:0170_copy_discovery_fields
- Migration 'services:0170_copy_discovery_fields' is marked for no-dry-run.
> services:0171_auto__del_field_iscsitargetglobalconfiguration_iscsi_discoveryauthmeth
> services:0172_auto__add_field_iscsitargetextent_iscsi_target_extent_serial
> services:0173_auto__del_field_iscsitarget_iscsi_target_serial
> services:0174_auto__add_iscsitargetgroups
> services:0175_target_to_groups
- Migration 'services:0175_target_to_groups' is marked for no-dry-run.
> services:0176_auto__del_field_iscsitarget_iscsi_target_portalgroup__del_field_iscsit
> services:0177_auto__del_field_iscsitargetgroups_iscsi_target_type
> services:0178_auto__add_fiberchanneltotarget
> services:0179_auto__add_field_iscsitarget_iscsi_target_mode
> services:0180_auto__del_unique_iscsitargettoextent_iscsi_extent__add_unique_iscsitar
> services:0181_auto__add_field_snmp_snmp_v3_authtype__add_field_snmp_snmp_v3_privprot
> services:0182_auto__add_unique_iscsitargetgroups_iscsi_target_iscsi_target_portalgro
> services:0183_auto__chg_field_fiberchanneltotarget_fc_target
> services:0184_auto__del_fiberchanneltotarget__add_fibrechanneltotarget
> services:0185_auto__add_field_iscsitargetextent_iscsi_target_extent_ro
> services:0186_auto__add_field_ssh_ssh_kerberosauth
> services:0187_auto__add_field_nfs_nfs_srv_16
> services:0188_auto__add_field_ssh_ssh_bindiface
> services:0189_auto__add_field_nfs_nfs_srv_v4_v3owner
> services:0190_dup_webdav
- Migration 'services:0190_dup_webdav' is marked for no-dry-run.
- Loading initial data for services.
Running migrations for vcp:
- Migrating forwards to 0002_auto__add_vcenterconfiguration.
> vcp:0001_initial
- Migration 'vcp:0001_initial' is marked for no-dry-run.
> vcp:0002_auto__add_vcenterconfiguration
- Loading initial data for vcp.
Running migrations for support:
- Migrating forwards to 0003_auto__add_field_support_support_email.
> support:0003_auto__add_field_support_support_email
- Loading initial data for support.
Running migrations for directoryservice:
- Migrating forwards to 0057_auto__add_field_activedirectory_ad_disable_freenas_cache.
> directoryservice:0041_auto__add_field_ldap_ldap_schema
> directoryservice:0042_auto__add_kerberossettings
> directoryservice:0043_auto__chg_field_ldap_ldap_binddn
> directoryservice:0044_auto__add_field_idmap_rfc2307_idmap_rfc2307_ssl__add_field_idmap_rfc23
> directoryservice:0045_auto__add_field_activedirectory_ad_netbiosname_b
> directoryservice:0045_auto__add_field_idmap_rfc2307_idmap_rfc2307_ldap_user_dn_password
> directoryservice:0046_auto__add_kerberosprincipal
> directoryservice:0047_migrate_kerberos_keytabs_to_principals
- Migration 'directoryservice:0047_migrate_kerberos_keytabs_to_principals' is marked for no-dry-run.
> directoryservice:0048_auto__add_field_activedirectory_ad_kerberos_principal__add_field_ldap_
> directoryservice:0049_populate_kerberos_principals
- Migration 'directoryservice:0049_populate_kerberos_principals' is marked for no-dry-run.
> directoryservice:0050_auto__del_field_activedirectory_ad_kerberos_keytab__del_field_ldap_lda
> directoryservice:0051_auto__del_field_kerberoskeytab_keytab_principal
> directoryservice:0052_change_ad_timeout_defaults
- Migration 'directoryservice:0052_change_ad_timeout_defaults' is marked for no-dry-run.
> directoryservice:0053_auto__del_field_activedirectory_ad_netbiosname__add_field_activedirect
> directoryservice:0054_auto__add_field_activedirectory_ad_allow_dns_updates
> directoryservice:0055_auto__add_field_ldap_ldap_netbiosname_a__add_field_ldap_ldap_netbiosna
> directoryservice:0056_migrate_ldap_netbiosname
- Migration 'directoryservice:0056_migrate_ldap_netbiosname' is marked for no-dry-run.
> directoryservice:0057_auto__add_field_activedirectory_ad_disable_freenas_cache
- Loading initial data for directoryservice.
Running migrations for account:
- Migrating forwards to 0023_auto__add_field_bsdusers_bsdusr_microsoft_account.
> account:0023_auto__add_field_bsdusers_bsdusr_microsoft_account
- Loading initial data for account.
Running migrations for network:
- Migrating forwards to 0018_auto__add_field_alias_alias_vip__add_field_alias_alias_v4address_b__ad.
> network:0016_auto__add_field_interfaces_int_vip__add_field_interfaces_int_vhid__add
> network:0017_auto__add_field_globalconfiguration_gc_hostname_b
> network:0018_auto__add_field_alias_alias_vip__add_field_alias_alias_v4address_b__ad
- Loading initial data for network.
Running migrations for sharing:
- Migrating forwards to 0034_fix_wizard_cifs_vfsobjects.
> sharing:0032_auto__add_field_cifs_share_cifs_storage_task
> sharing:0033_add_periodic_snapshot_task
- Migration 'sharing:0033_add_periodic_snapshot_task' is marked for no-dry-run.
> sharing:0034_fix_wizard_cifs_vfsobjects
- Migration 'sharing:0034_fix_wizard_cifs_vfsobjects' is marked for no-dry-run.
- Loading initial data for sharing.
Running migrations for system:
- Migrating forwards to 0100_auto__chg_field_tunable_tun_value.
> system:0093_auto__add_field_advanced_adv_boot_scrub
> system:0094_add_model_backup
> system:0095_auto__add_field_advanced_adv_periodic_notifyuser
> system:0096_auto__add_field_systemdataset_sys_uuid_b
> system:0097_auto__add_field_alert_timestamp
> system:0098_auto__add_field_alert_node__del_unique_alert_message_id__add_unique_al
> system:0099_auto__add_field_certificate_cert_chain__add_field_certificateauthority
> system:0099_email_pwenc
- Migration 'system:0099_email_pwenc' is marked for no-dry-run.
! Error found during real run of migration! Aborting.
! Since you have a database that does not support running
! schema-altering statements in transactions, we have had
! to leave it in an interim state between migrations.
! You *might* be able to recover with: (migration cannot be dry-run; cannot discover commands)
! The South developers regret this has happened, and would
! like to gently persuade you to consider a slightly
! easier-to-deal-with DBMS (one that supports DDL transactions)
! NOTE: The error which caused the migration to fail is further up.
Error in migration: system:0099_email_pwenc
The following content types are stale and need to be deleted:
system | registration
Any objects related to these content types by a foreign key will also
be deleted. Are you sure you want to delete these content types?
If you're unsure, answer 'no'.
Type 'yes' to continue, or 'no' to cancel: Traceback (most recent call last):
File "/usr/local/www/freenasUI/manage.py", line 42, in <module>
execute_from_command_line(sys.argv)
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 399, in execute_from_command_line
utility.execute()
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 392, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 242, in run_from_argv
self.execute(*args, **options.__dict__)
File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 285, in execute
output = self.handle(*args, **options)
File "/usr/local/lib/python2.7/site-packages/south/management/commands/migrate.py", line 111, in handle
ignore_ghosts = ignore_ghosts,
File "/usr/local/lib/python2.7/site-packages/south/migration/__init__.py", line 220, in migrate_app
success = migrator.migrate_many(target, workplan, database)
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 256, in migrate_many
result = migrator.__class__.migrate_many(migrator, target, migrations, database)
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 331, in migrate_many
result = self.migrate(migration, database)
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 133, in migrate
result = self.run(migration, database)
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 114, in run
return self.run_migration(migration, database)
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 84, in run_migration
migration_function()
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 60, in <lambda>
return (lambda: direction(orm))
File "/usr/local/www/freenasUI/../freenasUI/system/migrations/0099_email_pwenc.py", line 24, in forwards
do_encrypt(orm['system.Email'], 'em_pass')
File "/usr/local/www/freenasUI/../freenasUI/system/migrations/0099_email_pwenc.py", line 18, in do_encrypt
setattr(obj, field, notifier().pwenc_encrypt(getattr(obj, field)))
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py", line 5740, in pwenc_encrypt
nonce = get_random_bytes(8)
File "/usr/local/lib/python2.7/site-packages/Crypto/Random/__init__.py", line 41, in get_random_bytes
return _UserFriendlyRNG.get_random_bytes(n)
File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 228, in get_random_bytes
return _get_singleton().read(n)
File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 215, in _get_singleton
_singleton = _LockingUserFriendlyRNG()
File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 159, in __init__
_UserFriendlyRNG.__init__(self)
File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 86, in __init__
self._ec = _EntropyCollector(self._fa)
File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 53, in __init__
self._osrng = OSRNG.new()
File "/usr/local/lib/python2.7/site-packages/Crypto/Random/OSRNG/posix.py", line 83, in new
return DevURandomRNG(*args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/Crypto/Random/OSRNG/posix.py", line 44, in __init__
f = open(self.name, "rb", 0)
IOError: [Errno 2] No such file or directory: '/dev/urandom'
Exception AttributeError: "'DevURandomRNG' object has no attribute 'closed'" in <bound method DevURandomRNG.__del__ of <Crypto.Random.OSRNG.posix.DevURandomRNG object at 0x80b62a0d0>> ignored
May 22 20:46:20 BNAS manage.py: [system.alert:219] Alert module '<replication_status.ReplicationStatusAlert object at 0x8101bf0d0>' failed: no such column: storage_replication.repl_followdelete May 22 20:46:32 BNAS manage.py: [system.alert:219] Alert module '<replication_status.ReplicationStatusAlert object at 0x8101bf0d0>' failed: no such column: storage_replication.repl_followdelete May 22 20:46:33 BNAS syslog-ng[5943]: syslog-ng starting up; version='3.5.6' May 22 20:46:33 BNAS kernel: pid 1971 (syslog-ng), uid 0: exited on signal 6 (core dumped) May 22 20:47:11 BNAS alert.py: [system.alert:219] Alert module '<replication_status.ReplicationStatusAlert object at 0x80b3d23d0>' failed: no such column: storage_replication.repl_followdelete May 22 20:48:11 BNAS alert.py: [system.alert:219] Alert module '<replication_status.ReplicationStatusAlert object at 0x80b3d23d0>' failed: no such column: storage_replication.repl_followdelete May 22 20:49:12 BNAS alert.py: [system.alert:219] Alert module '<replication_status.ReplicationStatusAlert object at 0x80b3d23d0>' failed: no such column: storage_replication.repl_followdelete May 22 20:50:12 BNAS alert.py: [system.alert:219] Alert module '<replication_status.ReplicationStatusAlert object at 0x80b3d23d0>' failed: no such column: storage_replication.repl_followdelete May 22 20:51:12 BNAS alert.py: [system.alert:219] Alert module '<replication_status.ReplicationStatusAlert object at 0x80b3d23d0>' failed: no such column: storage_replication.repl_followdelete May 22 20:51:20 BNAS manage.py: [system.alert:219] Alert module '<replication_status.ReplicationStatusAlert object at 0x8101bf0d0>' failed: no such column: storage_replication.repl_followdelete May 22 20:52:12 BNAS alert.py: [system.alert:219] Alert module '<replication_status.ReplicationStatusAlert object at 0x80b3d23d0>' failed: no such column: storage_replication.repl_followdelete May 22 20:53:12 BNAS alert.py: [system.alert:219] Alert module '<replication_status.ReplicationStatusAlert object at 0x80b3d23d0>' failed: no such column: storage_replication.repl_followdelete May 22 20:54:13 BNAS alert.py: [system.alert:219] Alert module '<replication_status.ReplicationStatusAlert object at 0x80b3d23d0>' failed: no such column: storage_replication.repl_followdelete
