SOLVED Update (Check Now) problem...
hexcentral
First of I would like to thank the FreeNAS community & ixSystems for a really amazing NAS system.
Having got on well with 9.2.x, I thought I'd give 9.3-Beta a go. After a few installation hiccups, everything seemed to work well. In some cases better than in the previous version. Anyway with that procrastination out the way...
I've come across a small issue, I don't know if it's my fault (please don't shout at me if it is!!).
When I log on to the console and go SYSTEM -> UPDATE -> "Check Now" I get:-
Request Method: GET
Request URL: http://192.168.0.2/system/update/check/
Software Version: FreeNAS-9.3-BETA-c65d7db-x64
Exception Type: KeyError
Exception Value:
'Notice'
Exception Location: /usr/local/lib/freenasOS/Manifest.py in Notice, line 194
Server time: Mon, 24 Nov 2014 19:14:17 +0000
Traceback:
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response
105. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view
156. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
22. return view_func(request, *args, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/system/views.py" in update_check
1350. 'handler': handler,
File "/usr/local/lib/python2.7/site-packages/django/shortcuts/__init__.py" in render
53. return HttpResponse(loader.render_to_string(*args, **kwargs),
File "/usr/local/lib/python2.7/site-packages/django/template/loader.py" in render_to_string
169. return t.render(context_instance)
File "/usr/local/lib/python2.7/site-packages/django/template/base.py" in render
140. return self._render(context)
File "/usr/local/lib/python2.7/site-packages/django/template/base.py" in _render
134. return self.nodelist.render(context)
840. bit = self.render_node(node, context)
File "/usr/local/lib/python2.7/site-packages/django/template/base.py" in render_node
854. return node.render(context)
File "/usr/local/lib/python2.7/site-packages/django/template/loader_tags.py" in render
123. return compiled_parent._render(context)
62. result = block.nodelist.render(context)
File "/usr/local/lib/python2.7/site-packages/django/template/defaulttags.py" in render
305. return nodelist.render(context)
298. match = condition.eval(context)
File "/usr/local/lib/python2.7/site-packages/django/template/defaulttags.py" in eval
867. return self.value.resolve(context, ignore_failures=True)
File "/usr/local/lib/python2.7/site-packages/django/template/base.py" in resolve
585. obj = self.var.resolve(context)
735. value = self._resolve_lookup(context)
File "/usr/local/lib/python2.7/site-packages/django/template/base.py" in _resolve_lookup
789. current = current()
File "/usr/local/lib/freenasOS/Manifest.py" in Notice
194. return self._dict[NOTICE_KEY]
Exception Type: KeyError at /system/update/check/
Exception Value: 'Notice'
Request information
GET
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
Variable Value
csrftoken 'bF3upEBoLlVxbMK94dZMvNPEgDN9uXGU'
fntreeSaveStateCookie 'root'
sessionid 'k1ljb8nwbrqbxwxqvgpw4t5pb4f6k2p0'
META
Variable Value
HTTP_CONTENT_TYPE 'application/x-www-form-urlencoded'
PATH_INFO u'/system/update/check/'
SERVER_SOFTWARE 'nginx/1.6.2'
CSRF_COOKIE u'bF3upEBoLlVxbMK94dZMvNPEgDN9uXGU'
REQUEST_METHOD 'GET'
wsgi.url_scheme 'http'
HTTP_HOST '192.168.0.2'
REMOTE_PORT '55094'
DOCUMENT_ROOT '/usr/local/etc/nginx/html'
wsgi.multiprocess False
HTTP_ACCEPT_LANGUAGE 'en-US,en;q=0.5'
HTTP_ACCEPT 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8'
SCRIPT_NAME u''
SERVER_NAME 'localhost'
DOCUMENT_URI '/system/update/check/'
REDIRECT_STATUS '200'
GATEWAY_INTERFACE 'CGI/1.1'
REMOTE_ADDR '192.168.0.3'
SERVER_PORT '80'
HTTP_CONNECTION 'keep-alive'
wsgi.version (1, 0)
HTTP_REFERER 'http://192.168.0.2/'
HTTP_USER_AGENT 'Mozilla/5.0 (Windows NT 6.1; WOW64; rv:33.0) Gecko/20100101 Firefox/33.0'
wsgi.errors <flup.server.fcgi_base.TeeOutputStream object at 0x812d60290>
QUERY_STRING ''
HTTP_ACCEPT_ENCODING 'gzip, deflate'
HTTP_COOKIE 'csrftoken=bF3upEBoLlVxbMK94dZMvNPEgDN9uXGU; sessionid=k1ljb8nwbrqbxwxqvgpw4t5pb4f6k2p0; fntreeSaveStateCookie=root'
CONTENT_LENGTH ''
SERVER_PROTOCOL 'HTTP/1.1'
SERVER_ADDR '192.168.0.2'
REQUEST_URI '/system/update/check/'
HTTP_X_REQUESTED_WITH 'XMLHttpRequest'
wsgi.run_once False
wsgi.input <flup.server.fcgi_base.InputStream object at 0x812d56fd0>
wsgi.multithread True
I would be grateful if someone knows a fix/solution.
S
sef
Guest
This has already been fixed; you can get around it by using the CLI:
freenas-update -C /var/db/system/update check && freenas-update -C /var/db/system/update update && reboot
(Alternately, use the system update option in the console menu.)
