UniFi network controller
itsmatyii
Hello. I have UniFi Network Controller with version 8.0.24 installed in a jail with "pkg install unifi8". And currently there is an update avaliable to version 8.0.28. And I don't know how should I update it without losing all my data. Any suggestions? Thank you.
in the jail, perform a pkg upgrade. (if you didn't already, you may need to get on the "latest" pkg train: echo 'FreeBSD: { url: "pkg+http://pkg.FreeBSD.org/${ABI}/latest" }' > /usr/local/etc/pkg/repos/FreeBSD.conf, run pkg upgrade after that)
restart the jail.
It may take a little time to come up after such an upgrade as the database is often updated on the first startup following the upgrade.
I note that the current pkg version is 8.0.26, so you shouldn't expect to be on the absolute bleeding edge under FreeBSD.
