I have installed the unifi controller app from the default store and from the truechart store.
I am able to setup and import my settings.
but when i try to adapt any of the devices or use the mgrate from the old controller then it will not work.
the devices are offline.
sometimes i see the icon going orange like it is adopting.
but it never comes online in any of the portals.
When i check the status on for this example my 8 port poe switch i see the status as rejected.
No info in the logs of the controller.
Model: US-8-60W
Version: 6.5.59.14777
MAC Address: fc:ec:da:4c:ff:2d
IP Address: 192.168.178.29
Hostname: US-8-60W
Uptime: 1515 seconds
NTP: Synchronized
Status: Server Reject (http://192.168.178.94:8080/inform)
I can ping the controller.
when i open http://192.168.178.94:8080 in my webbrowser i am being redirected to the dashboard on https (8443)
when i do curl -I http://192.168.178.94:8080/inform
I see
HTTP/1.1 400
Transfer-Encoding: chunked
Date: Sat, 23 Sep 2023 21:42:37 GMT
Connection: close
So it seems like the inform part is not working...
I have setup an addon on my Home assistant for now.
But i like to have everything in my dockers on the truenas server.
Any one with a solution for this?
A quick test with my HA addon and the connection.
When i check the info directly on the same switch now it is connected with the controller on HA.
US-8-60W-US.6.5.59# info
Model: US-8-60W
Hostname: US-8-60W
Uptime: 667 seconds
NTP: Synchronized
Status: Connected (http://192.168.178.49:8080/inform)
When i do a curl on the inform adres i get the same result.
US-8-60W-US.6.5.59# curl -I http://192.168.178.49:8080/inform
HTTP/1.1 400
Date: Sat, 23 Sep 2023 22:00:19 GMT
Connection: close
Model: US-8-60W
Hostname: US-8-60W
NTP: Synchronized
I see
HTTP/1.1 400
Connection: close
Model: US-8-60W
Hostname: US-8-60W
Uptime: 667 seconds
NTP: Synchronized
HTTP/1.1 400
Connection: close
