Unexpected reboot occured during pool scrub
MrBucket101
I suspect a hardware failure is in my future. For the second time in 4 months, my system has rebooted during a pool scrub. I'm generally looking for advice on how to pinpoint or predict where my shortcoming could be.
For some background, this system has been issue free and stable for the last 3 years.
Hardware:
Dell r720xd
2x 750w PSU
2x e5-2697v2
192GB DDR3 ECC
12x 8TB HGST NAS
2x LSI 9211-8i (IT MODE)
ESXi 7.0
FreeNAS VM is given 96GB of RAM, and the HBA's are passed through to the VM. FreeNAS has direct access to the disks
Pool Layout
raidz3 - No L2ARC, No SLOG
Pool scrubs occurs on the 1st/15th of every month.
SMART Short tests are scheduled to run weekly
SMART Long tests are scheduled to run every other week
I've scheduled the smart tests and the scrubs so that they don't overlap.
I've attached a copy of the smart tests from all 12 drives.
The following test on one fo the drives, stood out to me, as it did encounter an error. But that was last month. and the drive has since passed additional tests without issue.
I logged into the idrac of my machine, and went through the logs there, and I didn't see anything that stood out. Nor did I see any alerts in the esxi logs. That leads me to beleive one of the drives is beginning to fail, as that's the only hardware that isn't connected to the host.
Are there any other diagnostics or tests I could run that would help me narrow down the issue? So far it seems all is fine, but that clearly isn't the case.
Device Model:     HGST HDN728080ALE604
Serial Number:    R6GSANPY
LU WWN Device Id: 5 000cca 263ca9c94
Firmware Version: A4GNW91X
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Oct 15 11:54:55 2020 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (  101) seconds.
capabilities:              (0x5b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      (1326) minutes.
SCT capabilities:            (0x003d)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   133   133   054    Pre-fail  Offline      -       108
  3 Spin_Up_Time            0x0007   152   152   024    Pre-fail  Always       -       443 (Average 424)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       68
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   128   128   020    Pre-fail  Offline      -       18
  9 Power_On_Hours          0x0012   097   097   000    Old_age   Always       -       21674
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       62
 22 Unknown_Attribute       0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       983
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       983
194 Temperature_Celsius     0x0002   200   200   000    Old_age   Always       -       30 (Min/Max 16/49)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       1
SMART Error Log Version: 1
ATA Error Count: 1
    CR = Command Register [HEX]
    FR = Features Register [HEX]
    ER = Error register [HEX]
    ST = Status register [HEX]
Error 1 occurred at disk power-on lifetime: 20951 hours (872 days + 23 hours)
  When the command that caused the error occurred, the device was doing SMART Offline or Self-test.
  ER ST SC SN CL CH DH
  84 41 00 00 00 00 00  Error: ICRC, ABRT at LBA = 0x00000000 = 0
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 00 00 b8 3a 7e 40 00  12d+18:33:58.829  READ FPDMA QUEUED
  60 00 00 b8 39 7e 40 00  12d+18:33:58.828  READ FPDMA QUEUED
  60 80 00 38 39 7e 40 00  12d+18:33:58.827  READ FPDMA QUEUED
  60 00 00 38 38 7e 40 00  12d+18:33:58.826  READ FPDMA QUEUED
  60 28 00 10 38 7e 40 00  12d+18:33:58.825  READ FPDMA QUEUED
# 1  Short offline       Completed without error       00%     21594         -
# 2  Extended offline    Completed without error       00%     21522         -
# 3  Short offline       Completed without error       00%     21426         -
# 4  Short offline       Completed without error       00%     21210         -
# 5  Extended offline    Completed without error       00%     21136         -
# 6  Short offline       Completed without error       00%     21042         -
# 7  Extended offline    Completed without error       00%     20990         -
# 8  Short offline       Completed without error       00%     20874         -
# 9  Extended offline    Completed without error       00%     20806         -
#10  Short offline       Completed without error       00%     20706         -
#11  Short offline       Completed without error       00%     20467         -
#12  Extended offline    Completed without error       00%     20403         -
#13  Short offline       Completed without error       00%     20299         -
#14  Short offline       Completed without error       00%     20131         -
#15  Extended offline    Completed without error       00%     20086         -
#16  Short offline       Completed without error       00%     19963         -
#17  Short offline       Completed without error       00%     19723         -
#18  Extended offline    Completed without error       00%     19653         -
#19  Short offline       Completed without error       00%     19555         -
#20  Short offline       Completed without error       00%     19387         -
#21  Extended offline    Completed without error       00%     19321         -
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p11 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
  • smartctl.txt
JaimieV
Anything logged in your iDRAC lifecycle log for the event?
Could your HBAs be overheating? Scrub is intensive. Try bumping your base fan speed up in the BIOS (I think it is)?
