Unable to Partition boot drive after replacement [9.2.0.1]
hunkeelin
I tried the nas4free forums but it doesn't seem that responsive so I am going to try my luck here.
version: 9.2.0.1 - Shigawire (revision 972)
My boot drive is in raid 1. One of the hdd is failing so I replaced it.
When I go to gui, I can't seem to create 3 partitions. Here's the info:
Under Disks|Software RAID|RAID1|management
It looks like this
Under Disks|Software RAID|RAID1|tools: (Screen shot below)
rebuilding root
rebuilding boot
rebuilding swap
I'm only able to rebuild root. For swap and boot I get the following message
`geom: No such provider: ada0p3.` for the boot drop down menu
`geom: No such provider: ada0p3.` for the swap drop down menu
So this is what I deduce. ada0 the hdd I just replaced only have one partition. I am unable to create 3 partition that mirrors ada1.
This is really critical as the machine is only sitting on one os drive. If that drive die the machine will die.
thanks
D
dlavigne
Guest
You'll have to stick with the nas4free forums as that is the correct operating system and has nothing to do with FreeNAS.
