unable to connect to rrdcached: connection refused status=61
refruta
Hi everyone, I had a power outage and my freenas turned off when I turned it on again, I got that message and I could not go through the help web.
D
dlavigne
Guest
Has this been resolved? If not, do you get the console menu if you click enter on that screen?
refruta
if it was solved thanks I had to disable an option in the log files.
