I don't know if this is a VMWare issue, a FreeBSD issue, or if it was present in 11.3 as well.
Configuration:
As usual, I created a new VM with a viurtual disk for the OS, and installed TrueNAS 12 beta on it. No issues, smooth as anything
I then added the physical disk, to let the VM have a full physical disk to use as a data pool. But it didn't matter whether I tried the 10TB SAS3 disk, or the 1TB NVMe disk, I got a fatal boot-time error. I cleaned the drive in DISKPART, I deleted the partitioning, I repartitioned RAW in Windows (no drive letter or disk format), I allocated partitions or entire raw drive in VMWare, added as a HDD or a "generic SCSI device",
... it didn't matter what I did, it hit a fatal error halfway through the FreeBSD boot sequence and the boot aborted and killed the VM.
Can anyone check if this is reproducible? Screenshot and VMWare log below, error lines emphasised. if it should be reported, who should it be reported to?:
Configuration:
Asus WS X299 series motherboard latest bios i9-10980xe CPU
9211-8i HBA flashed latest with attached 10TB SAS3 HDD confirmed working
Samsung 970 Pro NVMe PCIe 3 x4 M-key in a PCIE slot, also confirmed working
Intel NVMe SSD system disk
Windows 10 clean install up to date
VMWare workstation 15.5.6 latest clean installed
Scenario:As usual, I created a new VM with a viurtual disk for the OS, and installed TrueNAS 12 beta on it. No issues, smooth as anything
2020-07-09T01:16:06.789+01:00| vmui| I005: DEVCREAT: Found a device: \\.\PhysicalDrive1
2020-07-09T01:16:06.789+01:00| vmui| I005: OBJLIB-FILEBE : FileBEIoctl: ioctl operation failed on '\\.\PhysicalDrive1' : The request is not supported (3276802)
2020-07-09T01:16:06.789+01:00| vmui| I005: HOSTDISK-WIN32: Facts: Cap=2000409264 Phys C/H/S=124519/255/63 BIOS C/H/S=124519/255/63 Adap=SCSI
2020-07-09T01:16:06.789+01:00| vmui| I005: DEVCREAT: PartitionTables : 1
2020-07-09T01:16:06.789+01:00| vmui| I005: DEVCREAT: At 0
2020-07-09T01:16:06.790+01:00| vmui| I005: VMHSGetDataFileKey: Could not get the dataFileKey from VMDB
2020-07-09T01:16:06.825+01:00| vmui| I005: CMksCtl::LayoutGuestWindow: Render normal window.
2020-07-09T01:16:06.825+01:00| vmui| I005: CMksCtl::LayoutGuestWindow: Source: 1024x768 @ 0,0 Target: 1024x768 @ 0,0.
2020-07-09T01:16:07.337+01:00| vmui| I005: VMHSGetDataFileKey: Could not get the dataFileKey from VMDB
2020-07-09T01:16:07.337+01:00| vmui| I005: DEVCREAT: Found a device: \\.\PhysicalDrive1
2020-07-09T01:16:07.337+01:00| vmui| I005: OBJLIB-FILEBE : FileBEIoctl: ioctl operation failed on '\\.\PhysicalDrive1' : The request is not supported (3276802)
2020-07-09T01:16:07.338+01:00| vmui| I005: HOSTDISK-WIN32: Facts: Cap=2000409264 Phys C/H/S=124519/255/63 BIOS C/H/S=124519/255/63 Adap=SCSI
2020-07-09T01:16:07.338+01:00| vmui| I005: DEVCREAT: PartitionTables : 1
2020-07-09T01:16:07.338+01:00| vmui| I005: DEVCREAT: At 0
2020-07-09T01:16:07.338+01:00| vmui| I005: VMHSGetDataFileKey: Could not get the dataFileKey from VMDB
2020-07-09T01:16:07.352+01:00| vmui| I005: CDS: Fetching repository index from https://softwareupdate.vmware.com/cds/index.xml
2020-07-09T01:16:07.352+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/index.xml.
2020-07-09T01:16:07.639+01:00| vmui| I005: CDS: Fetching vendor index for VMW from https://softwareupdate.vmware.com/cds/vmw-desktop/vmrc-linux.xml
2020-07-09T01:16:07.639+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/vmrc-linux.xml.
2020-07-09T01:16:07.639+01:00| vmui| I005: CDS: Fetching vendor index for VMW from https://softwareupdate.vmware.com/cds/vmw-desktop/player-linux.xml
2020-07-09T01:16:07.640+01:00| vmui| I005: CDS: Fetching vendor index for VMW from https://softwareupdate.vmware.com/cds/vmw-desktop/vmrc-windows.xml
2020-07-09T01:16:07.640+01:00| vmui| I005: CDS: Fetching vendor index for VMW from https://softwareupdate.vmware.com/cds/vmw-desktop/player-windows.xml
2020-07-09T01:16:07.640+01:00| vmui| I005: CDS: Fetching vendor index for VMW from https://softwareupdate.vmware.com/cds/vmw-desktop/vmrc-macos.xml
2020-07-09T01:16:07.640+01:00| vmui| I005: CDS: Fetching vendor index for VMW from https://softwareupdate.vmware.com/cds/vmw-desktop/fusion.xml
2020-07-09T01:16:07.641+01:00| vmui| I005: CDS: Fetching vendor index for VMW from https://softwareupdate.vmware.com/cds/vmw-desktop/ws-linux.xml
2020-07-09T01:16:07.641+01:00| vmui| I005: CDS: Fetching vendor index for VMW from https://softwareupdate.vmware.com/cds/vmw-desktop/ws-windows.xml
2020-07-09T01:16:07.667+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/player-linux.xml.
2020-07-09T01:16:07.700+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/vmrc-windows.xml.
2020-07-09T01:16:07.727+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/player-windows.xml.
2020-07-09T01:16:07.761+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/vmrc-macos.xml.
2020-07-09T01:16:07.789+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/fusion.xml.
2020-07-09T01:16:07.822+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws-linux.xml.
2020-07-09T01:16:07.856+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws-windows.xml.
2020-07-09T01:16:07.889+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.1.6/12368378/windows/core/metadata.xml.gz.
2020-07-09T01:16:07.945+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...1.7/12989993/windows/packages/metadata.xml.gz.
2020-07-09T01:16:07.981+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/15.5.0/14665864/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.077+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...0.3/12422535/windows/packages/metadata.xml.gz.
2020-07-09T01:16:08.111+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.3/5115892/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.144+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.8/7098237/windows/packages/metadata.xml.gz.
2020-07-09T01:16:08.176+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/15.1.0/13591040/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.203+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.5/5234757/windows/packages/metadata.xml.gz.
2020-07-09T01:16:08.251+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.9/7535481/windows/packages/metadata.xml.gz.
2020-07-09T01:16:08.286+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.1.0/7370693/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.313+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/15.0.0/10134415/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.345+01:00| vmui| E002: CDS error: No description for bulletin 2d735280-8f9e-4223-9a5f-a1316fcbcfce
2020-07-09T01:16:08.345+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...5.0/14665864/windows/packages/metadata.xml.gz.
2020-07-09T01:16:08.375+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.8/7098237/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.408+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...5.2/15785246/windows/packages/metadata.xml.gz.
2020-07-09T01:16:08.440+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.1.0/3272444/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.466+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.1/4542065/windows/packages/metadata.xml.gz.
2020-07-09T01:16:08.496+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.1.3/9474260/windows/packages/metadata.xml.gz.
2020-07-09T01:16:08.528+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/15.5.2/15785246/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.654+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...1.0/13591040/windows/packages/metadata.xml.gz.
2020-07-09T01:16:08.687+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...5.6/16341506/windows/packages/metadata.xml.gz.
2020-07-09T01:16:08.719+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.1.0/3272444/windows/packages/metadata.xml.gz.
2020-07-09T01:16:08.752+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.1.8/14921873/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.783+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.1.1/7528167/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.814+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.4/5192485/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.847+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.0.0/6661328/windows/packages/metadata.xml.gz.
2020-07-09T01:16:08.877+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.2/4638234/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.905+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.1.7/12989993/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.935+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.0.1/3160714/windows/core/metadata.xml.gz.
2020-07-09T01:16:08.965+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.4/5192485/windows/packages/metadata.xml.gz.
2020-07-09T01:16:08.999+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...1.5/10950780/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.031+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.1.3/9474260/windows/core/metadata.xml.gz.
2020-07-09T01:16:09.059+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.0.0/2985596/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.090+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.3/5115892/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.120+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.1.1/3770994/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.151+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.0.0/6661328/windows/core/metadata.xml.gz.
2020-07-09T01:16:09.181+01:00| vmui| E002: CDS error: No description for bulletin b08c8cf1-6949-4072-83d7-a3d95533d897
2020-07-09T01:16:09.181+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.0.1/3160714/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.215+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.1.4/10722678/windows/core/metadata.xml.gz.
2020-07-09T01:16:09.244+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.2/4638234/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.275+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.1.1/7528167/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.310+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.1.0/7370693/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.341+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.7/5813279/windows/core/metadata.xml.gz.
2020-07-09T01:16:09.371+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.1.2/8497320/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.402+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...0.4/12990004/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.433+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...0.0/10134415/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.465+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...5.1/15018445/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.499+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/15.0.3/12422535/windows/core/metadata.xml.gz.
2020-07-09T01:16:09.531+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/15.5.1/15018445/windows/core/metadata.xml.gz.
2020-07-09T01:16:09.637+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.6/5528349/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.670+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/info-only/ws-windows/8.0.0/metadata.xml.gz.
2020-07-09T01:16:09.869+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.7/5813279/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.901+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.0/4352439/windows/packages/metadata.xml.gz.
2020-07-09T01:16:09.935+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.1.1/3770994/windows/core/metadata.xml.gz.
2020-07-09T01:16:09.968+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...0.2/10952284/windows/packages/metadata.xml.gz.
2020-07-09T01:16:10.002+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/15.5.6/16341506/windows/core/metadata.xml.gz.
2020-07-09T01:16:10.067+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.1.5/10950780/windows/core/metadata.xml.gz.
2020-07-09T01:16:10.096+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/15.5.5/16285975/windows/core/metadata.xml.gz.
2020-07-09T01:16:10.162+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/15.0.2/10952284/windows/core/metadata.xml.gz.
2020-07-09T01:16:10.192+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...5.5/16285975/windows/packages/metadata.xml.gz.
2020-07-09T01:16:10.226+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...0.1/10737736/windows/packages/metadata.xml.gz.
2020-07-09T01:16:10.261+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/14.1.2/8497320/windows/core/metadata.xml.gz.
2020-07-09T01:16:10.291+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...1.6/12368378/windows/packages/metadata.xml.gz.
2020-07-09T01:16:10.326+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.5/5234757/windows/core/metadata.xml.gz.
2020-07-09T01:16:10.353+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...1.8/14921873/windows/packages/metadata.xml.gz.
2020-07-09T01:16:10.387+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.9/7535481/windows/core/metadata.xml.gz.
2020-07-09T01:16:10.416+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/15.0.4/12990004/windows/core/metadata.xml.gz.
2020-07-09T01:16:10.444+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.0/4352439/windows/core/metadata.xml.gz.
2020-07-09T01:16:10.562+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/c...1.4/10722678/windows/packages/metadata.xml.gz.
2020-07-09T01:16:10.593+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.0.0/2985596/windows/core/metadata.xml.gz.
2020-07-09T01:16:10.620+01:00| vmui| E002: CDS error: No description for bulletin 13e24cd8-f8f0-46d3-b2d7-7eeecfc2e415
2020-07-09T01:16:10.620+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.6/5528349/windows/core/metadata.xml.gz.
2020-07-09T01:16:10.649+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/15.0.1/10737736/windows/core/metadata.xml.gz.
2020-07-09T01:16:10.676+01:00| vmui| I005: CDS: Using NONE proxy (null):0 for https://softwareupdate.vmware.com/cds/vmw-desktop/ws/12.5.1/4542065/windows/core/metadata.xml.gz.
2020-07-09T01:16:10.707+01:00| vmui| I005: CDS: Change client state to CDS_SUCCESS, 288 bulletins available
2020-07-09T01:16:10.707+01:00| vmui| I005: cui::ComponentMgrCDS::RefreshComponentListWithDefaults: CDS_UNKNOWN_PRODUCT_ERROR for product player-linux
2020-07-09T01:16:10.707+01:00| vmui| I005: Win32U_GetFileAttributes: GetFileAttributesExW("C:\Program Files (x86)\VMware\VMware Workstation\darwin.iso", ...) failed, error: 2
2020-07-09T01:16:10.707+01:00| vmui| I005: Win32U_GetFileAttributes: GetFileAttributesExW("C:\Program Files (x86)\VMware\VMware Workstation\darwinPre15.iso", ...) failed, error: 2
2020-07-09T01:16:10.707+01:00| vmui| I005: Win32U_GetFileAttributes: GetFileAttributesExW("C:\Program Files (x86)\VMware\VMware Workstation\freebsd.iso", ...) failed, error: 2
2020-07-09T01:16:10.710+01:00| vmui| I005: cui::ComponentMgrCDS::RefreshComponentListWithDefaults: CDS_UNKNOWN_PRODUCT_ERROR for product ws-linux
2020-07-09T01:16:10.710+01:00| vmui| W003: cui::ComponentMgrCDS::RefreshComponentListWithDefaults: Install database empty! Overriding install state of ws-windows
2020-07-09T01:16:10.710+01:00| vmui| I005: CDS: Cds_SearchBulletins: Searching for product=(all) version=(latest) build=0
2020-07-09T01:16:10.713+01:00| vmui| I005: CDS: CdsUtil_QueryMsiByProductCode: {0147BD85-9983-40F9-8E81-29DA16EB7748} is unknown in the MSI database.
2020-07-09T01:16:10.713+01:00| vmui| W003: cui::ComponentMgrCDS::RecordBulletin: Install database empty! Overriding install state of ws-windows to "Same version installed"
2020-07-09T01:16:10.713+01:00| vmui| I005: Win32U_GetFileAttributes: GetFileAttributesExW("C:\Program Files (x86)\VMware\VMware Workstation\freebsd.iso", ...) failed, error: 2
2020-07-09T01:16:10.714+01:00| vmui| I005: CDS: Cds_SearchBulletins: Searching for product=(all) version=(latest) build=0
2020-07-09T01:16:10.714+01:00| vmui| I005: CDS: Cds_SearchBulletins: Searching for product=(all) version=(all) build=16341506
2020-07-09T01:16:10.715+01:00| vmui| I005: cui::ComponentMgrCDS::RefreshComponentListWithDefaults: CDS_UNKNOWN_PRODUCT_ERROR for product player-linux
2020-07-09T01:16:10.715+01:00| vmui| I005: Win32U_GetFileAttributes: GetFileAttributesExW("C:\Program Files (x86)\VMware\VMware Workstation\darwin.iso", ...) failed, error: 2
2020-07-09T01:16:10.715+01:00| vmui| I005: Win32U_GetFileAttributes: GetFileAttributesExW("C:\Program Files (x86)\VMware\VMware Workstation\darwinPre15.iso", ...) failed, error: 2
2020-07-09T01:16:10.715+01:00| vmui| I005: Win32U_GetFileAttributes: GetFileAttributesExW("C:\Program Files (x86)\VMware\VMware Workstation\freebsd.iso", ...) failed, error: 2
2020-07-09T01:16:10.718+01:00| vmui| I005: cui::ComponentMgrCDS::RefreshComponentListWithDefaults: CDS_UNKNOWN_PRODUCT_ERROR for product ws-linux
2020-07-09T01:16:10.718+01:00| vmui| W003: cui::ComponentMgrCDS::RefreshComponentListWithDefaults: Install database empty! Overriding install state of ws-windows
2020-07-09T01:16:10.718+01:00| vmui| I005: CDS: Cds_SearchBulletins: Searching for product=(all) version=(latest) build=0
2020-07-09T01:16:10.721+01:00| vmui| I005: CDS: CdsUtil_QueryMsiByProductCode: {0147BD85-9983-40F9-8E81-29DA16EB7748} is unknown in the MSI database.
2020-07-09T01:16:10.721+01:00| vmui| W003: cui::ComponentMgrCDS::RecordBulletin: Install database empty! Overriding install state of ws-windows to "Same version installed"
2020-07-09T01:16:10.721+01:00| vmui| I005: Win32U_GetFileAttributes: GetFileAttributesExW("C:\Program Files (x86)\VMware\VMware Workstation\freebsd.iso", ...) failed, error: 2
2020-07-09T01:16:10.721+01:00| vmui| I005: CDS: Cds_SearchBulletins: Searching for product=(all) version=(latest) build=0
2020-07-09T01:16:10.722+01:00| vmui| I005: CDS: Cds_SearchBulletins: Searching for product=(all) version=(all) build=16341506
2020-07-09T01:16:10.723+01:00| vmui| I005: CDS: Cds_SearchBulletins: Searching for product=tools-freebsd version=(all) build=16341506
2020-07-09T01:16:10.723+01:00| vmui| I005: cui::DownloadMgr::FetchComponents: Requested non-installed component but no update is available. Are you sure you're using the right update repository?
2020-07-09T01:16:19.742+01:00| vmui| I005: DlgUI: The firmware encountered an unexpected exception. The virtual machine cannot boot.
