Tun disappeared after upgrading
ZodiacUHD
Hello everyone,
i had a couple of jails connecting to PIA VPN via openvpn. After the update to 12.0 those jails don’t show any tun* after running ifconfig.
Did anyone have the same issue?
Cheers
colmconn
You probably just need to upgrades your openvpn PIA config files to the nextgen version. I just spend the last couple of hours trying to figure this out. Everything was working fine until this morning.
ZodiacUHD
Thanks for the reply, do you mean i need to download the openvpn.zip file again from PIA?
colmconn
You want https://www.privateinternetaccess.com/openvpn/openvpn-nextgen.zip. I wrote the script below to setup PIA in a jail. I've got the resolvconf stuff in it commented out because I no longer use it. It might be useful to you.
#!/usr/local/bin/bash
## set -x
## In part based on
## https://gist.github.com/jedediahfrey/6d475dcc34c710f62a7c
## Includes setup of DNS servers after the VPN tunnel is brought up
## and taken down by openvpn. This functionality relies on
## https://github.com/masterkorp/openvpn-update-resolv-conf.git
## Doesn't try to build openvpn from ports since openvpn versions
## greater then 2.3.9 already include PW_SAVE support complied in The
## script will check your version of openvpn and if it is less than
## 2.3.9 it will terminate
## LICENSE: GPL2
## https://www.gnu.org/licenses/gpl-2.0.txt
# set -x
getUsername() {
    read user
    echo $user
getPassword() {
    ## turn off echo to the password does not appear on the screen
    stty -echo
    read pass
    ## turn on echo again
    stty echo
    echo "$pass"
updatePkgs() {
    /usr/sbin/pkg update -f
    /usr/sbin/pkg upgrade -y
isOpenVpnInstalled() {
    ovpn=`which openvpn`
    if [ "x$ovpn" == "x" ] ; then
    return 0
    else
    return 1
    fi
installPackages() {
    env ALWAYS_ASSUME_YES=YES pkg install openvpn
openVpnSupportsPwSave() {
    ovpn_version=`openvpn --version | head -1 | awk -F ' ' '{print $2}'`
    major=`echo $ovpn_version | cut -d '.' -f 1`
    minor=`echo $ovpn_version | cut -d '.' -f 2`
    patch=`echo $ovpn_version | cut -d '.' -f 3`
    ## see https://www.freshports.org/security/openvpn
    ## if [ $major -eq 2 ] && [ $minor -ge 3 ] && [ $patch -gt 9 ] ; then
    if [ $major -eq 2 ] && [ $minor -ge 3 ] ; then
    echo "OpenVPN appears to support PW_SAVE. Does not need upgrading"
    return 0
    else
    echo "OpenVPN appears to not support PW_SAVE. You should install it from ports before rerunning this script."
    echo "Commands like the following may help"
    echo "/usr/sbin/portsnap fetch"
    echo "/usr/sbin/portsnap extract"
    echo "cd /usr/ports/security/openvpn"
    echo "/usr/bin/make config-recursive"
    echo "/usr/bin/make install"
    echo "/usr/bin/make clean"
    exit 1
    fi
getIpAddress () {
    #    if [ -x "/usr/local/bin/wget" ] ;  then
    #    ip=`wget -qO- http://wtfismyip.com/text`
    #    elif [ -x "/usr/local/bin/curl" ] ; then
    #     ip=`curl -s http://wtfismyip.com/text`
    #    fi
    ip=`fetch -q -o- http://wtfismyip.com/text`
    echo $ip
chooseVpnServer() {
    echo "Available VPN servers are:" > /dev/stderr
    i=1
    for ff in *.ovpn ; do
    echo -e "\t$i:\t$ff" > /dev/stderr
    i=`expr $i + 1`
    done
    echo -n "Enter a number corresponding to a server listed above: " > /dev/stderr
    read choice
    echo `ls -1 *.ovpn | sed "${choice}q;d"`
### END OF FUNCTION DEFINITIONS
if ! isOpenVpnInstalled ; then
    # check open vpn version
else
    echo "Could not find OpenVPN. Attempting to install"
    installPackages
fi
openVpnDir=/usr/local/etc/openvpn
rm -fr $openVpnDir
mkdir $openVpnDir
cd $openVpnDir
echo "Downloading private internet access OpenVPN configuration files"
fetch https://www.privateinternetaccess.com/openvpn/openvpn-nextgen.zip
piaOpenVpnZipFilename=openvpn-nextgen.zip
#echo "Getting update-resolv-conf script"
#git clone https://github.com/masterkorp/openvpn-update-resolv-conf.git
## set the correct paths
#echo "Setting correct path to bash and resolvconf script"
#sed -i ".orig" 's#bin/bash#usr/local/bin/bash#;s#^RESOLVCONF.*#RESOLVCONF=/sbin/resolvconf#' $openVpnDir/openvpn-update-resolv-conf/update-resolv-conf.sh
## now tell resolvconf to manage the epair interface so that DNS
## settings will be updated automatically by the update-resolv-conf.sh
## when it is invoked by openvpn
#cp /etc/resolv.conf /tmp/resolv.conf
#RESOLVCONF=$(which resolvconf)
## clear the state directory
#$RESOLVCONF -I
#dev=`ifconfig -l | tr ' ' '\n' | grep -v lo | grep -v pflog`
#dev_count=$( echo $dev | wc -l )
#if [[ $dev_count -gt 1 ]] ; then
#    echo "Got more than one configured interface. This script can't handle more then one configured interface. Exiting"
#    exit 256
#fi
#echo "Configuring $RESOLVCONF to manage the DNS resolution servers for ${dev}"
# $RESOLVCONF -a "${dev}.inet" < /tmp/resolv.conf
## rm -f /tmp/resolv.conf
if [ -f ${piaOpenVpnZipFilename} ] ; then
    unzip -q ${piaOpenVpnZipFilename}
    rm -f ${piaOpenVpnZipFilename}
    for  ovpn in *.ovpn ; do
    ## echo "Editing $ovpn"
    # Tell OpenVPN where to find the username and password
    if grep -q auth-user-pass "$ovpn" ; then
        sed -i ".orig" "s#auth-user-pass#auth-user-pass $openVpnDir/pass.txt#" "$ovpn"
    else
        echo "auth-user-pass $openVpnDir/pass.txt" >> "$ovpn"
    fi
    # Tell OpenVPN what script to run when the tunnel is brought
    # up and down
    echo "script-security 2" >> "$ovpn"
    echo "up   /usr/local/libexec/openvpn-client.up" >> "$ovpn"
    echo "down /usr/local/libexec/openvpn-client.down" >> "$ovpn"
    ## Try to keep the link alive by pinging every 60 seconds if
    ## nothing is sent across the tunnel. Any server side
    ## provided keep-alive or ping and ping-restart options will
    ## override this keep-alive directive
    echo "keepalive 60 120" >> "$ovpn"
    ## run the up/down script on restarts of the tun interface. Hopefully
    ## this will eliminate DNS resolution issues
    echo "up-restart" >> "$ovpn"
    #Use full path names to avoid ambiguity
    # sed -i ".orig" -e "s#ca\.crt\$#$openVpnDir/ca\.crt#g" "$ovpn"
    # sed -i ".orig" -e "s#crl\.pem\$#$openVpnDir/crl\.pem#g" "$ovpn"
    ## Finally replace the spaces in the filename with underscores
    ## to make typing the filenames less of a PITA
    ovpn2=`echo $ovpn | sed "s/ /_/g"`
    mv -f "$ovpn" "$ovpn2"
    rm -f "${ovpn}.orig"
    done
fi
## now ask for the username and password used to authenticate to the VPN provider
echo -n "Enter VPN service username: "
username=`getUsername`
echo -n "Enter VPN service password (it will not appear on screen when you type it): "
password=`getPassword`
passwordFile=$openVpnDir/pass.txt
touch $passwordFile
chmod 600 $passwordFile
echo $username > $passwordFile
echo $password >> $passwordFile
echo ""
vpnServer=`chooseVpnServer`
echo "You chose $vpnServer as your VPN server"
echo "Enabling OpenVPN"
sysrc openvpn_enable=YES
echo "Setting your VPN server of choice"
sysrc openvpn_configfile="$openVpnDir/$vpnServer"
echo "Getting remote host name from OpenVPN config file"
remote_host_name=$( grep "remote " $openVpnDir/$vpnServer | awk '{print $2}' )
echo "Remote host is: $remote_host_name"
echo "Converting remote host to list of class C IPV4 networks"
remote_host_nets=( $( host $remote_host_name | \
        grep -v "is an alias for" | \
              awk '{print $4}' | \
              sed 's#\.[0-9][0-9]*$##g' | \
              sort | \
              uniq ) )
echo "Got ${#remote_host_nets[@]} class C networks for the remote host name"
cat /dev/null > $openVpnDir/openvpn_nets_ipfw_table.txt
for (( ii=0; ii< ${#remote_host_nets[@]}; ii++ )) ; do
    echo "Remote host net[${ii}]: ${remote_host_nets[$ii]}"
    echo "${remote_host_nets[$ii]}.0/24" >> $openVpnDir/openvpn_nets_ipfw_table.txt
done
echo "Your DNS resolvers are:"
cat /etc/resolv.conf
oldIp=`getIpAddress`
service openvpn start
sleepDuration=5
echo "Waiting ${sleepDuration} second for OpenVPN to start"
sleep ${sleepDuration}
newIp=`getIpAddress`
echo "IP before starting OpenVPN: $oldIp"
echo "IP after  starting OpenVPN: $newIp"
if [ "$oldIp" != "$newIp" ] ; then
    echo "Success! OpenVPN appears to have started successfully."
else
    echo "The old IP and new IP are the same. It appears that OpenVPN didn't start correctly"
fi
ZodiacUHD
## set -x
## In part based on
## LICENSE: GPL2
# set -x
getUsername() {
    read user
    echo $user
getPassword() {
    stty -echo
    read pass
    stty echo
    echo "$pass"
updatePkgs() {
    return 0
    else
    return 1
    fi
installPackages() {
    return 0
    else
    exit 1
    fi
getIpAddress () {
    #    fi
    echo $ip
chooseVpnServer() {
    i=1
    i=`expr $i + 1`
    done
    read choice
else
    installPackages
fi
rm -fr $openVpnDir
mkdir $openVpnDir
cd $openVpnDir
#$RESOLVCONF -I
#    exit 256
#fi
    else
    fi
    # up and down
    done
fi
touch $passwordFile
echo ""
              sort | \
              uniq ) )
done
sleepDuration=5
else
fi
i’m gettin the error attached, do you have any idea?
ZodiacUHD
chmod u+x /script.sh
./script.sh
To be fair it worked fine on 11.3, i'm having this issue on 12.0 Jail.
Hazz
Oh god I spent ages scratching my head over this, thanks for the heads up regarding PIA!
Agurri
Thank you very much. It help a lot. My PIA jail was not working since yesterday morning and I couldn't figure out why. Your script works very well. The only thing I'm having issue right now is if I reboot my jail, the resolvconf file is emptied and I need to either rerun the script, or manually add the nameserver back in the file.
