Kevin20554
- Oct 9, 2013
I am using an old PC with the following configuration and it's getting really slow.
- Running FreeNAS 0.7.2 Sabanda (revision 8191)
- i386-embedded on Intel(R) Pentium(R) 4 CPU 2.66GHz
- 1 Gig of Ram
- WD Caviar® WD1800JB. (160 gig)
- Utilizing UFS file system
- Nic Card ??? Probably 10/100
- Network 10/100 switch
It takes about 4 minutes to transfer 4332, .jpg files of about 284MB.
Is this slow?
I am thinking of changing and making another box with the following configuration:
- Installing FreeNAS 9.1.1 or 8.3.2
- INTEL (CORE 2 DUO ) E7400 @ 2.8 GHz (to be purchased)
- Planning to upgrade it to 8 Gigs of Ram
- NIC 10/100/1000
- Utilizing ZFS file system to support the following H.D. setup.
- I already have (2) - ST31000528AS • Barracuda 7200.12 SATA 3Gb/s 1TB H.D.s
trying to mirror these drives.
And add two additional, 2TB drives in the future (to be mirroed)
And finally and 5th drive possibly for backup purposes of the above.
- All above H.D.s would be in an external 5 bay enclosure (Do not know what to purchase).
I don't know whether this PC's SATA, would be able to handle all the above hard drives?
1. I was wondering whether the above setup would be sufficient for home/office use, to use as and extra storage to transfer files back and forth between two users? Running Win 7.
2. What type/brand of external 5 bay enclosure is recommended?
3 I don't know whether this PC's SATA, would be able to handle all the above hard drives?
4. Is an additional SATA card required to run 5 additional hard drives?
5. I would appreciate any recommendation for the above setup.
Thank you.
- 1 Gig of Ram
Is this slow?
- NIC 10/100/1000
Thank you.
