pirateghost
Unintelligible Geek
 - Feb 29, 2012
Yeah. It just worked for me after I put in the user/pass I wantedThats not the problem. The web interface gives me an error 503 service unavailable. Why is this?
I am using it in freenas. I have never logged into any interface in a shell window.Surely other people have been able to access the nzbget web interface with it installed on freenas? Or is everyone using it with the interface in the shell window?
Got it working using this start command: nzbget -c /etc/nzbget.conf -s
How do I have nzbget start up automatically if I reboot the FreeNAS machine?
Hold on a second that is actually not easy if someone hasn't already done the work to build the script. Not sure if that exists for this application? If it does you can just put nzbget_enable="YES" in /usr/local/etc/rc.confLike any other service in freebsd.
https://forums.freenas.org/index.php?threads/autostart-for-nzbget-on-jail.26237/Hold on a second that is actually not easy if someone hasn't already done the work to build the script. Not sure if that exists for this application? If it does you can just put nzbget_enable="YES" in /usr/local/etc/rc.conf
pkg install nzbget
WebDir=/usr/local/share/nzbget/webui ConfigTemplate=/usr/local/share/nzbget/nzbget.conf ControlUsername= ControlPassword=
sysrc 'nzbget_enable=YES'
 pkg install unrar within the jail?which unrar
root@NZBget:/ # which unrar /usr/local/bin/unrar root@NZBget:/ #
cp $(ls -r /etc/certificates/letsencrypt-*.key | head -1) /jails/nzbget/root/usr/local/etc/nzbget
