Trying to create a RAID Z2 pool results in a RAID Z3 pool.
inntel
TrueNAS Scale current Beta 1.
Supermicro server with X7DBU motherboard and XEON E5440 CPU.
LSI HBA controller with 12 x Hitachi Ultrastar HUA721010KLA330 1TB hard drives.
I am trying to create a single RAID Z2 pool but ponce it's created it shows up as a RAID Z3 and thus I loose about 1TB of capacity. I know the hardware I'm using is antique but I'm looking for capacity and the data scrubbing, not speed.
I've searched the forums and didn't find anything. Is this a known bug?
Can you show the pool status (which is the part which will specifically show which RAIDZ version the pool is)?
inntel
The first pic shows the pool with the capacity of a RAID Z3 and the second one labels it as RAID Z2. However when I put a file on the server and looked at the properties from a Linux client it reports it as having 9TB of free space left so I assume then that it is really a RAID Z2.
Thank-you for the response.
NugentS
How about showing the result of zpool status at the command line?
Incidently are you getting confused by the size of the disks. 1TB != 1TiB. for example a 6TB disk is actually only 5.5TB when in a pool due to the way manufacturers label disks you don't get a binary terrabyte - you get a decimal terrabyte
inntel
This could be the explanation. I ran the zpool status (thanks btw) command and got this info:
truenas3# zpool status
pool: Storage-103
state: ONLINE
NAME STATE READ WRITE CKSUM
Storage-103 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
So it does show a raidz2 configuration, I am just surprised at how much space the raidz2 takes.
