Trying to allow ports lower than 1023 in jail results in Operation not permitted
wuxia
I'm trying to allow ports lower than 1023 in my jail:
# sysctl net.inet.ip.portrange.reservedhigh=79
net.inet.ip.portrange.reservedhigh: 1023
sysctl: net.inet.ip.portrange.reservedhigh=79: Operation not permitted
Works fine on the host:
net.inet.ip.portrange.reservedhigh: 79 -> 79
What can be the reason for that and is there some workaround?
MisterE2002
it is possible:
echo "net.inet.ip.portrange.reservedhigh=0" >> /etc/sysctl.conf
Change => "Jail Properties" => "securelevel" from 2 to -1
Patrick M. Hausen
Jails can perfectly well without any additional configuration listen to ports < 1024. If the process is run by root (inside the jail) and if it is a VNET jail. Which should be the default today. VNET is just superior in about every aspect compared to host based networking.
wuxia
Ports under 1024 are "privileged ports" and are typically reserved for processes running as root.
What service are you attempting to run, and can it be run on a higher port instead?
It's a web server so I need port 80/443 to avoid higher ports as it will be awkward to use.
jgreco
Resident Grinch
Well, that's definitely a matter of opinion. There's a lot more screwing around involved in setting up a VNET based jail, and it can be very useful to have the host platform controlling stuff like routing and firewalls.
Patrick M. Hausen
Our entire hosting stack would not work without a separate working 127.0.0.1 in each individual customer jail. So yes, I'm biased, but I have a convincing business case. If you use jails for multi-tenancy, VNET is the way to go.
Sure, but my contract manager at Dell/HPE/Lenovo told me that more virtualization is more betterer, and since I'm already running a rack full of servers running a bunch of VMs that load balance my web app and database serving 20 users (5 concurrent), surely using virtual networking inside my TrueNAS jails (TrueNAS hosted on Hyper-V) would be extra bettererer, no?
(Not a jab at @Patrick M. Hausen in any way, I like VNET, but day job gets boring if I can't make fun of enterprise vendor nonsense after spending an aftenoon fiddling with a tape library).
