Truenas scale VM pool offline
krlsantcard
Hello everyone,
New on truenas, i have install truenas scale on VMWare Pro, window 10, and all hdd virtual. (For testing)
I noticed if the power off on my pc, when I start again truenas vm, the pool go offline.
Any suggestions. Maybe some wrong config on my setting VM when I create the hdd?. For the moment I can't afford buy hdd. Thanks
xyno
1. Do you have any logs/screenshots ?
2. With power off on my pc, do you meen turning it off without shutting it down propperly ?
