Hi there, I recently converted my TrueNAS Core to SCALE and it has been a pretty good experience so far.
I did that mainly in order to use many of the nice Apps/Charts out of the TrueCharts catalog and from the Docker Hub.
Basically I was able to deploy some of the offered public charts and Docker Images - whereby I've to admit that I am an old man and sometimes was struggeling with the huge variety of options to select or set. At the end I just deleted charts/containers which I had trouble with.
The problem started, when I started to 'play around' with Helm Charts. There was no problem to deploy them. I fear I made mistakes by modifying some settings.
All of a sudden I could not any longer display my installed Apps - only the turning circle is shown forever. After a restart of the system none of my Apps were started.
To make a long story short: I need an advice how to to completely clean up that kubernetes/docker environment in order to start over from Zero - without jeopardizing my data on that TrueNAS SCALE Server.
